my 89 pings a bit when it is hot.
it only happens when it is hot and after a low rpm shift. any suggestions?
A little nonsense now and then
is relished by the wisest men.
comin from undrneath your car?? could be your heat sheild.
-Scott
88ancient
-Its not illegal until you get caught-
if nothing else works check your timing and make sure your advance mechanism is functioning properly
What grade of gas are you using? The FI models had slightly higher compression than the carbed models and usually require at least 89 octane to prevent pinging. I can sometimes get by on 87 octane (regular) in the winter, but mine will ping like a son-of-a-bitch in the summer on anything less than mid grade.
i reterded the timing when i bought the car and it made it ping less, but it's at the factory setting now. i guess it's big $$$ gas for me. time to raise the right foot i guess
where is the sound coming from? if its from the engine then i guess its the gas (ive never heard of this though)... but if its coing from like under your car it might be something simple, for example the heat shield could be loose or where your headers meet the engine... it really could be anything.
Mods:
90/91 CRX Si Wheels on Yokohama's, HP Racing 4'' oval exhaust, Arospeed Coilovers (0-4" drop, slammed at about 3.5" now), Modified Integra Short Ram Intake, Clear Front Bumper Lights(wired on w/ hyperwhite bulbs), Sidemarkers, White Interior Trim(Console, Vents, Handles, etc...), Removed Emblems, Type-R shift knob, Aiwa CD Deck, Sony Xplod 6x9's
17.06 @ 80.9 mph
http://www.cardomain.com/id/slammedlxi
