Results 1 to 14 of 14
Thread: Egr Remove
    89' LX-i Accord
    Miami
    Egr Remove
    What will happen if i remove my egr on my lx-i? Will my engine light come on? And how do i remove it? Thanx for the help!
    Nov 2002
    Ridin Dirty in New York
    yeah if you take the EGR youll get a check engine light and the engine will run funny. You cant just remove it because itll give you a huge vaccuum leak in the intake manifold, but just taking the vaccuum line off the top of it will disable it, but also give you a code.
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    i gotta find were to replace that thing. I guess mine is going out.. were is it located, i have an idea that it's on my manifold, but other than that I have no clue what it looks like or anything
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    Feb 2003
    1988 Accord Limited
    Montréal (Québec) Canada
    Is the EGR valve just for the fuel injected models or does the carbureted model have one also? I've replaced just about everything and my car still runs like cr@p, someone suggested the EGR valve...
    You are only young once, but you can stay immature indefinately.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    You know whats funny, from what I understood those things would happen if you remove it, BUT when I cut mine off because I couldnt get it free from the header the CEL never came on. Granted I never drove it for a couple of hours straight because I was going to be storing it. It never idled weird, no CEL, and I believe that getting rid of it is a little better for performance.
    '88 LX-i Coupe --- LS/Vtec
    1987 Honda Accord LX-i HB
    Montana
    I was wonderin the same thing. see i just recieved my dc header (cuase my pacesetter took a shit) any way i got the egr tube off just fine but now i am having a hell of a time getting it hooked up to the new dc header, it just wont f*cking do it. i have fooled with it for hours. What i want to know is has anyone one else run into this problem? How did you fix it? I am i need of serious help! Thanks in advance.
    Colt Cams Tri-flo regrind/CAI/DC Header/Hi Flo Cat/2.25in.cat back/Accel Coil/Magnecore 8.5 wires/ H&Rsprings/ Tokico front & rear/15in Technomagnesio/some dents/287k mi. RIP
    2.0Si User Elijah's Avatar
    Nov 2002
    A20A3T
    Edmonton, Ab, Canada
    Help is right my egr is gone to what a problem with are cars.
    Stop bench racing and pick up a wrench
    I know my spelling sucks and I suck with computers deal with it.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    2 crowbars 4 hands. One pushing on the egr with a crowbar so that the end will go into the header end. Another crowbar to guide the nut into the correct place while pushing the nut so that the thread catches. When it catches, continue pushing on the crowbar and thread the nut in place. Hope that helps.
    Knoxville, TN
    were is it located?............
    LX User Whitehonda's Avatar
    Nov 2002
    Then (89 LX-i) Now (94 EX)
    Michigan
    Yellow Arrow
    Cameron
    Nov 2002
    yeah thats the EGR tube, and follow that up to the intake manifold and it bolts right into it, and right where it bolts in there is this funky looking can the top side of the intake and thats the EGR. Well, when i disabled my egr i noticed a little better torque, then i got my CEL coming on so I reconnected it. If the egr is functioning properly then it should have NO effect on the engines idle.
    Knoxville, TN
    excellent, Thanx i'll take a look at it tommorow.. any way to test it?
    Montana
    well, after walkin away from it for a night to cool off (i had lost all patience and frustration set in) i came back to it after work and after a couple of tries i finally got the damn thing. What a pain in the ass that was. After the fight with that egr the rest was cake. The new DC header is on, and its very nice. I woul like to show everyone the reason not to choose pacesetter, maybe in another post.
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Yeah there is. I tested mine and it's toast..stuck. I'm gonna plug it sometime when it gets warmer here in Canada.
    You can test it by simply trying to move the bottom up and down or disconnect the vaccume hose from it and connect a vaccume gauge to it and apply a vaccume, vaccume should remain constant and the engine should shut off, if it don't then it needs to be cleaned or buy a new one or a used one that works.
    BTW, the EGR valve looks like the valve on your intake duct except it's directly on the intake manifold.
    -Mike
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
  1. how do i remove a hub nut
    By levon2008 in forum 3geez Accords
    Last Post: 02-17-2008, 10:46 PM
  2. How do I remove the following:
    By hanginbyaccord in forum 3geez Accords
    Last Post: 08-14-2007, 01:18 PM
  3. How do I remove this
    By ottomatic in forum Interior & Exterior Care
    Last Post: 08-01-2006, 12:48 AM
  4. anyone know how to remove this???
    By racerx in forum 3geez Accords
    Last Post: 07-16-2004, 08:33 PM
  5. How do i remove my
    By franks89sir in forum 3geez Accords
    Last Post: 01-30-2003, 09:23 AM
