I have 86 accord lx, CA emissions, 2bbl Keihin carb, 2.0L auto, trans. The problem I'm having is I had mechanic replace the carb recently. He said that after replacing he started the car and antifreeze started to leak through the base plate. He says he never saw that before. He talked to the place where I bought the carb and was told to disconnect a hose or hoses that go to the carb or manifold I'm not sure I wasn't in on the conversation. The carb guy said if you do this it wouldn't hurt anything because we don't use that for the carb because we are in CA it was meant for cars in colder weather. This would stop the antifreeze from leaking through the carbs base plate. My mechanic tried it but couldn't get the leak to stop so he removed the carb and sealed a hole where the antifreeze was coming from. It worked for awhile but now it's leaking again. Has anyone had this problem? And do you know which hose or hoses will stop the leak. The carb guy said it was simple to bypass this problem I don't know if my guy understands what he was saying.
Thanks
