Results 1 to 16 of 16
Thread: 1986 Hatch LXi 5 speed
    Jan 2016
    1987 Accord DX 5speed. 86 Hatch LX-i 5speed
    Seattle
    I've done I lot to this car to get it back on the road from sitting outside for 2 years. Right now I'm replacing the head gasket after I found my oil with just a little foam in it last time I changed the oil. After watching some guys on youtube porting their heads and seeing how easy it seamed all be it a little time consuming, i got the crazy idea to port the head in my car while I had the head off. Now my car is in all sorts of pieces but the head looks really nice though.
    Jan 2016
    Seattle
    Re: 1986 Hatch LXi 5 speed
    I tried to get some of the intake manifold too
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Looks good 👍
    Way cool!
    Jan 2016
    Seattle
    Lapping the valves took a little more than i expected finding minor pits it the valve seats(probably from sitting for 2 years doing nothing) but after lapping the valves I got good seats on all the valves. I'm also replacing the the valve stem seals along with the camshaft seal.
    Lapping the valves
    New valve stem seals
    Valve springs going back on
    All back together again
    You know, of all the work I've done on cars, I've never rebuilt a head. There are just too many special and expensive tools required. I always take them in. Nice work!
    Jan 2016
    Seattle
    It wasn't that expensive, $20 for a cheap Dremel another $20 for some sanding and polishing bits, $20 for valve spring compressor tool, $15 for valve lapping tool and compound, and a wire wheel grinder is nice but not necessarily. Of course a head gasket kit that came with all the gaskets, seals, and O-rings I needed.
    Jan 2016
    Seattle
    It's a time consuming process though, took me close to a week
    I guess I read all that stuff in the manual about grinding valves with multiple angles and so forth and just said, "Nope."
    Jan 2016
    Seattle
    If you want to go all out you could replace the valves and get the valve seats machined and resurface the head. But I just cleaned the surface really good and lapped the valve seats.
    Jan 2016
    Seattle
    Just got this test pipe, to do a cat delete.
    It is listed to fit a 90-93 Accord, and looked like it might fit my car but it DOESN'T FIT the stock exhaust because one of the flanges is rotated different. However when I get my new OBX header it will work, can't wait.
    Jan 2016
    Seattle
    I guess I should post some pics of the actual car☺
    She's a little dirty, but she's a working car.
    Feb 2016
    Florida
    Quote Originally Posted by 87rustbucket View Post
    How did you post pictures. I'm having problems uploading them
    Jan 2016
    Seattle
    I post them on Imgur first, then use the link to post it here, and uncheck "retrieve remote file"
    Feb 2016
    Florida
    Cool thanks
    Jan 2016
    Seattle
    My OBX header arrived and so did my heat wrap
    First I sealed the slip fittings on it with extreme hear JBweld.
    Then I sprayed it with hi-temp silicone coating.
    Then I wrapped it and sprayed it again.
  1. 1986 LXi hatch
    By Honda#1 in forum Ebay & Craigslist Finds
    Last Post: 06-17-2017, 07:41 PM
  2. 1986 honda accord 5 speed for sale
    By joseph.hill254 in forum 3geez Accords
    Last Post: 05-15-2015, 07:22 AM
  3. WTB:1986-1989 Accord LX-i/SE-i 5 Speed in Texas
    By Legend_master in forum Wanted
    Last Post: 03-01-2011, 07:24 AM
  4. 1986 New Accord Ad DX Hatch
    By philendrick in forum Classic Honda Pics & Videos
    Last Post: 05-24-2002, 08:19 PM
