Results 1 to 7 of 7
Thread: Replacing front passenger window
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Question Replacing front passenger window
    Well, someone decided to smash my front passenger window and steal the stereo and tools out of my car. Has anyone else had to deal with a front passeneger window replacement on a sedan? Since it will be a while until I have the tools to pull the door apart again (or pul one from the yard) I thought I'd check to see if anyone else has had to do this before. How bad a job is it? So far the best price I've found for a replacement window at a U-pull it place is $25. Does that sound reasonable?
    Thanks
    Mike
    Sounds reasonable to me. I've never done a replacement but I have put in a new crank assembly and it was a booger. I don't imagine it will be too tough but try not to scratch your window when sliding it in.
    YK86's Avatar
    Oct 2000
    BC, Canada
    The front window is very easy to replace. If I remember right, the how-to I wrote up for removing your window regulator explains how to rip out the window first so you might want to check that in the how-to section.
    www.b20accord.com
    Banned Tim Yoak's Avatar
    1986 accord hb IHAVE A HOME PAGE SEE MY PROFILE
    moultrie, ga
    all you have to do is remove the door panel and remove the two bolts that hold in the glass. just get a shop vac to get all the broken glass out of the door. or pull the door panel and drive to a do it yourself car wash and vaccume it out. the one from the junkyard probably has the two connectors at the bottom of the glass. just bolt it back in.
    Nov 2000
    $25 is a good price. I had to replace the passenger front window in my coupe (yeah, it's bigger than the sedan window). I bought it new at a glass wholesale place for $75. It's a PPG window just like the original.
    The procedure is pretty much as described by Tim above. The window will have the threaded parts already in the bottom of the glass so it should be prety obvious how to secure it. You definitely want to get all the bits of glass out of the door or you will hear it every tijme you close it.
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    one more thing....
    before you button it up, check the way the window seals, a road test is a good idea..windows have some adjustment range and if you don't get it just right, it won't fully seal and you have annoying wind noise.
    just got back from a week in Japan and sorry to report I did not see one damm 3g the entire time..lots of toyotas and unkwnon brand cars for US
    Nov 2000
    Actually, on these cars I noticed no adjustment. It was not necessary, anyway, as the window was a perfect fit.
  1. Passenger window help
    By chavezbrian101 in forum Interior & Exterior Care
    Last Post: 01-11-2014, 01:50 PM
  2. how do i replace my passenger's window? please help
    By neoblue89lxi in forum 3geez Accords
    Last Post: 10-12-2003, 04:15 PM
  3. WTB: Passenger side window
    By Accordination in forum Trading Post
    Last Post: 07-03-2003, 01:18 PM
  4. Replacing front passenger window
    By AZmike in forum Classic Honda Community Chat
    Last Post: 02-19-2003, 09:54 AM
