Results 1 to 4 of 4
Thread: Weber carb leak
    Nov 2017
    Weber carb leak
    My weber 38 is leaking gas. I think I know where its coming from, but i’m not sure.
    It’s that squarish looking part that has a hole in each corner, and has a big circle in the middle.
    Re: Weber carb leak
    Did you have a question?
    Nov 2017
    Re: Weber carb leak
    Lol whoops, forgot to type the question. Actually, it wasn’t leaking from there. The nuts holding down the carb were actually loose. So nvm.
    Gonna put on some loctite tonight when the car cools down. I might have forgetten to do so when i first put the carb on i remember putting it on the studs that go into the adapter plate and the screws that go into the intake manifold, but i may have missed the stud nuts.
    Re: Weber carb leak
    Glad you got it fixed.
  1. Weber 32/36 help vacuum leak?
    By Katzutoshi in forum Carburetor Tech
    Last Post: 03-03-2015, 08:19 PM
  2. 88 Accord LX Keihin Carb Swap to 32/36 DGEV Weber Carb
    By absolutezero479 in forum 3geez Accords
    Last Post: 11-23-2014, 08:49 PM
  3. Weber Carb??
    By stunna31061 in forum Performance
    Last Post: 12-15-2006, 05:15 PM
  4. weber carb
    By SlammedAccord89 in forum Carburetor Tech
    Last Post: 04-03-2004, 08:03 PM
  5. Vacuum Leak between Weber adapter and intake man.
    By Mike's89AccordLX in forum Carburetor Tech
    Last Post: 10-21-2003, 06:10 PM
