Results 1 to 10 of 10
Thread: 86 lxi fuel gauge and temperature gauge quit working ?
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I went to go drive the car today and I noticed the temperature gauge and the gas gauge was not working at all. the one wire sensor off the thermostat housing has been completely replaced with new wire and new connectors. Has anybody experienced this before. it has done this before about 5 years ago but then the next day it was back working again. What should my next move be replaced the gauge?
    Re: 86 lxi fuel gauge and temperature gauge quit working ?
    As a best practice, I like to squirt some dielectric grease in all my wire connections. It helps to prevent corrosion.
    And no, I haven't experienced it.
    Feb 2016
    Florida
    I'll try that thanks
    Both of those gauges share a common ground, I believe. Might figure out where that is, and make sure it's clean. They seem to be really picky about those connections.
    Feb 2016
    Florida
    I was thinking that I'll trace the wires back and see if I can find it thanks
    Feb 2016
    Florida
    update I did nothing and it's back working again maybe it will go another 5 years before it does it again
    Life with old cars. LOL
    SE-i Sedan 5 spd
    Well, I haven't posted to this site in quite awhile. Glad to see some old faces still here! And, I have something original to say.
    My SE-i sat for a couple of years before I needed the garage space. When I got it running I needed a new battery, which I requisitioned from my son's Lexus, totalled when a tree jumped out in front of him.
    It was a tight fit, but I got it in.
    When I started the car, however, the temperature gauge did not work. I replaced the sending unit, no help. I did have a complete gauge cluster (86k!) so figured I could just plunk it in if need be, but it bothered me that the gauge should break while it sat there.
    I did some other stuff, finally checking for continuity between the gauge and the sensor. Nothing. Long story short, under the battery tray runs the harness, and a rodent had done his job there.
    I haven't seen the car for a few years. Hope it's ok.
    Hey W. Good to hear from you again.
  1. temperature gauge not working
    By Ju_S12_Turbo in forum 3geez Accords
    Last Post: 07-01-2010, 03:55 AM
  2. How Does Your Temperature Gauge Behave?
    By kw_da in forum 3geez Accords
    Last Post: 10-15-2006, 09:50 AM
  3. temperature gauge location? (PLEASE LOOK AT THIS PIC))
    By detroit313 in forum 3geez Accords
    Last Post: 03-21-2006, 09:24 AM
  4. fuel gauge not working?
    By sns_vg in forum 3geez Accords
    Last Post: 12-12-2003, 03:33 PM
  5. Temperature Gauge
    By Seabass in forum 3geez Accords
    Last Post: 11-05-2002, 11:39 PM
