Got around to running the car today. It's taken me 2 months working on it on and off in between work schedule and sourcing parts. I seem to have a problem with oil pressure. I did manage to replace the main And rod bearings As the originals where in Badd order. The crankshaft is in good condition. Pick up filter in the Pan is not clogged. Also replaced the oil pump and the oil pressure Sending unit. I am using 10W40.
Test drove it for 40 minutes. Noticed the oil light was blinking to steady and blinking on and off when i got home. With the after market sending unit the wire doesn't even securely connect all the way. Never had an oil pressure problem prior to my rebuild. Searched around here and ordered the proper male to female fitting for pressure gauge usage so I can check what's going On. Should arrive in a few days. I also seem to have a horrible rough start. I need to rent a timing light as well but want to get the pressure problem in order
Any thoughts as to what could be going on?
