Results 1 to 9 of 9
Thread: DIY solution for egr pipe gasket?
    88 honda accord lxi
    Can't find this part anywhere. only came with my engine rebuild kit when i ordered it but i've had to take the pipe off a few times and now the gasket has disintegrated. Amazon/ ebay, honda aint got the part. what can I use as a replacement?
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: DIY solution for egr pipe gasket?
    You could probably get away with making your own gasket with gasket material
    Nov 2017
    You mean this gasket, right?
    If so, its a pretty universal part for most hondas. They should have it at your local auto parts store for a couple bucks
    88 honda accord lxi
    That one is readily available but im referring to gasket for the pipe that connects comes from the exhaust manifold to the engine
    I'd try re-using the old one if it isn't completely destroyed. But yeah, making your own would probably be the best bet.
    Mar 2012
    1988 Honda Accord LX-i 2 Door Coupe 5 Speed
    Charlotte, NC
    Assuming this is a fuel injected engine as the carb engine does not have an egr pipe gasket, part # you need is Honda 18721-PJ0-660 or Fel-Pro 72316
    LXi User AC439's Avatar
    86 LXi
    FL
    Donny, have you been able to find the gasket ? I need one as well. The Fel-pro part number is not for our car. The Honda number is discontinued.
    88 honda accord lxi
    Quote Originally Posted by AC439 View Post
    Nope, however i went to a machinist and had the guy carve a really thin aluminum piece sized to the egr pipe, coupled with a piece of gasket maker from the autoparts place. Worked great/ no leaks. Now I have an egr gasket that will last a long time. i could prolly get away with just using the aluminum
    86 LXi
    FL
    Donny, I ended up putting some permatex copper high temp gasket maker to the mating surfaces to seal it up. Works fine.
  1. Straight Pipe ? test pipe VS high flow cat
    By Acid X in forum Performance
    Last Post: 07-10-2006, 11:41 AM
  2. Need a solution for this.
    By lackej1971 in forum Carburetor Tech
    Last Post: 01-05-2006, 10:20 PM
  3. true flex pipe VS. Socket joint pipe
    By Ace in forum Performance
    Last Post: 04-27-2005, 07:53 PM
  4. Replies: 16
    Last Post: 11-30-2003, 02:43 PM
  5. Copper exhaust pipe gasket?
    By Mike's89AccordLX in forum 3geez Accords
    Last Post: 07-15-2003, 04:44 PM
