Results 1 to 4 of 4
Thread: 4X100 conversion
    carotman's Avatar
    Montreal South Shore
    4X100 conversion
    I have a really old trailer at home. My father had this trailer built in the early 80's. He gave it to me and I'm currently repainting/rebuilding it.
    The axle was custom made with 1G civic hubs/drums. My father, who worked at Honda (and still does), thought it would be cost effective to use old Honda parts he could have basically for free. The problem now is that Honda stopped using 4X120 wheels and it ended up being more of a problem in the long run.
    I hope I can convert the 4X120 to 4X100 and have a wide selection of wheels and tires for this older trailer.
    I was wondering if you guys know what parts I can use for this conversion. The axle is really simple. All it is is a piece of pipe with 1G Civic rear spindle welded on it. Then, the drums are bolted to the spindle. That's it. There's no back plate, no shoes, nothing.
    Could I just use a 1981 rear drum and call it a day? Can I re-use the bearings of do I need different ones?
    I need these parts!
    Aug 2018
    79 Accord
    UT
    Re: 4X100 conversion
    So I've have not done this conversion yet, however from reading the sticky about the conversion I would think all you would need to do is use the Prelude brake rotor from the swap list. Your not worried about the brake caliper mount. You may be able to get that rotor from a local parts store along with the bearings and wheel studs and bolt it on.
    LXi User 79cord's Avatar
    Melb, Aust.
    '82-85 (2nd) Accord, '79-86 (1st & 2nd) Prelude, '80-'83 (2nd) Civic rear drums should work, I suspect bearings hadn't changed though could be wrong.
    Handbrake cable arrangements made things more complicated fitting some of those on to cars.
    B0CKS's Avatar
    Jul 2016
    1988 DX Coupe
    Detroit MI
    I realize it wouldn't be the best answer, but have you considered running adapters to a bolt pattern? Just to keep things easy.
    4 X 120 to 4 X 100 Wheel Adapter
    [SIGPIC]
  1. 4x100 Lug Conversion (with Rear Disc Brakes)
    By babyhonduhdrama in forum 1geez Accords
    Last Post: 05-17-2020, 08:58 PM
  2. 4x100 Conversion Discussion
    By 2ndGenGuy in forum 1geez Tech & Performance
    Last Post: 04-05-2020, 01:46 PM
  3. I'm having fun with my 4x100 conversion right now
    By Hazwan in forum 1geez Tech & Performance
    Last Post: 09-14-2012, 04:55 AM
  4. 4x100 conversion dilemma. AHHHHH!
    Last Post: 05-14-2012, 02:30 PM
  5. 4x100 to 4x114.3 Conversion & What Offset
    By 88tandx in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-05-2005, 05:44 PM
