Results 1 to 12 of 12
Thread: Remove shifter rod from M/T
    88 honda accord lxi
    Going to eventually convert to a manual abd found an accord at the junkyard with a trans i will attempt to rebuild. Question, how do you disengage the shift rod from the transmission? I have disengaged it from the stick
    carotman's Avatar
    Montreal South Shore
    Re: Remove shifter rod from M/T
    There is a spring pin on the transmission that you need to punch out.
    88 honda accord lxi
    Im assuming im dropping the trans with the rod still engaged then? Or is there a way to do it in chassis? Cant find nuffin in the service manual about this part. Wheres the pin btw?
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Remove the bolt
    88 honda accord lxi
    Really afraid that was the answer . Bolt is rounded off
    88 honda accord lxi
    Got it. Pleasantly surprised by how small this thing is. I can pick this up with ease
    carotman's Avatar
    Oh yeah, there's pin on these cars (The Civic does).
    It's a bolt indeed
    88 honda accord lxi
    Too bad i went through the trouble of removing it only to find the internal speed sensor housing in the transmission is cracked/broken. Not sure if sonething like that can be fixed or not. Trans is still sitting in the trunk of the car in the junkyard
    Quote Originally Posted by Donnyten View Post
    The speed sensor is where the speedo cable goes into and two lines from the steering rack goto. It unbolts separate. There very expensive new.
    88 honda accord lxi
    Yep. I know.. but where it fits inside of the transmission is cracked. The sensor itself is fine. I dont know if it would be any difference. Wish i coulda took a picture
    Jun 2010
    Pffft, who needs a speedometer
    I'm pretty sure that could be fixed at a machine shop, but you might not like the price.
  1. how to get this *&^^%$ shifter out?
    By lostforawhile in forum Classic Honda Community Chat
    Last Post: 04-12-2009, 09:01 PM
  2. Shifter knob
    By 86ccord in forum Classic Honda Community Chat
    Last Post: 11-24-2007, 02:36 PM
  3. Shifter
    By jigga89SEi in forum 3geez Accords
    Last Post: 12-04-2005, 11:21 AM
  4. How to remove shifter
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 09-21-2003, 12:56 PM
