exactly, turfnnsurf had a shop make a 3inch custom welded intake that maurice (Chronoco) also got it from him. That wedge diaphram thingie is the bypass valve like mentioned above. I wont recommend it if ur filter is pretty close to ur frame. cause i heard someone say that u gotta be careful if u wanna make a bypass valve or any sort.
moving ur battery to the rear is not a pain at all, all u need to do is get a kit like Summit battery kit or something, run the 2gauge wire down the passenger side and thru the firewall or what not and clamp it tight with the given eye hole connector and join it where the stock cable is.
