Results 1 to 25 of 40
Thread: 84 Prelude Auto to Manual
    Jan 2019
    84 Honda Prelude
    Washington
    I recently bought an 83 prelude parts car with a manual transmission in it. The motor and transmission have about 130k miles on it. I pulled the motor last weekend and realized there are a few differences between the 83 and 84. One of the differences was the engine code, the '84 being a et2 and the 83 an es1, 2, or 3. Looking through engine parts, the only differences I could see were either in the intake manifold gasket or the exhaust manifold gasket. I'm wondering if the transmission will bolt up to the et2 block. I think it will, but I would like to confirm it here.
    The 84 prelude has 50k miles on it. I'm torn on if I should see this project to the end, or just leave it untouched.
    My possible plans are rebuilding the es1 motor, and installing a weber carb, or only swap the transmission in there.
    '85 lude
    houston
    Re: 84 Prelude Auto to Manual
    Trans should be the same... The carb ones have smaller axles and flyweel/clutch. Way back when I was broke and crazy I swapped the larger diff into my carb trans and ground down the housing to fit 2.0 axles and flywheel.
    Although, that said, I know 84+ is the same, 83 did have some oddities but I believe you should be fine. I've only ever seen an 83 one time, long ago. The 83 is CVCC, you are not going to want that head.
    Jan 2019
    84 Honda Prelude
    Washington
    I've decided to stick with the motor in the '84. I will probably start working on this project again next week starting with taking the glass out. Then I have to get rid of the parts car so I have room to work.
    Jan 2019
    84 Honda Prelude
    Washington
    Here's an update after a few months. I got the transmission rebuilt, and repainted the shift linkage, brackets, pedal assembly, etc. I don't have much pictures. Mostly I've been gathering parts and now I can get going with the project. This weekend I started removing the automatic and ended up getting stuck on the converter plate bolts. I will get that part figured out though.
    The only thing I'm not so sure about is the speed sensor and how to re-route the power steering lines. The manual speed sensor has two lines going into it, while the automatic speed sensor has two lines similar to the manual sensor, but just one more larger line. I can't upload a picture of it for some reason though. I know some people bypass that system by looping the lines together, but that won't help with the third line hanging around.
    carotman's Avatar
    Montreal South Shore
    Isn't the larger line just a vent?
    Jan 2019
    84 Honda Prelude
    Washington
    The larger line actually refills the reservoir after reading about it. There is a pump in the speed sensor that reduces steering assist as you gain speed, so I'm thinking the two smaller lines recirculate or reduce pressure somewhere else in the system.
    That being said I'll try out using the automatic speed sensor since the one that came off the manual transmission doesn't even have a third line.
    The guy who sold me that parts car gave me a shop manual for an '83. Even the speed sensor shown there has 3 lines, so I'm starting to think that speed sensor never belonged to that car anyways. He was having issues with the power steering system's reservoir cap blowing off.
    Jun 2010
    Mine only has 2 lines on the manual trans. I 5 speed swapped it at the end of last year. Maybe it's a Prelude thing but the auto speed sensor that came off my accord only has 2 lines as well and from what I've read are not interchangeable.
    As far as I can tell, the assist reduction is done in the sensor. My evidence is that I swapped the lines by mistake recently when I had to fix my clutch. It would give me no assist at a stop but full on assist at higher speed. Doing 70 and barely touching the wheel was an adventure.
    Are you talking about the post right in the center of the sensor? Cause that's where the speedometer cable goes..
    Originally posted by ShiRen:
    Jan 2019
    84 Honda Prelude
    Washington
    Whenever I take a picture of the speed sensor in my car it will not upload on this site.
    I did take a picture of what it looks like in the shop manual, and its the same.
    Yes, in the picture attached before is the hole for the cable.
    Jun 2010
    I've never seen one with three lines like that. Funky.
    Jan 2019
    84 Honda Prelude
    Washington
    Well got all the bolts out of the crank today. Then I looked at my parts and the clutch pilot bearing fits on the transmissions output shaft, but does not go into the flywheel. Grr... The ID on my flywheel is 0.750... and not 1.260 like the bearing OD. Was wondering if anyone has dealt with this before. I may just make a bushing out of bronze or some other soft metal and send it.
    Also working on searching around too.
    EDIT:
    After searching these cars do not use pilot bearings. They use bushings. I found a part number on NAPA that matches the OD and ID that I need, so no need to turn one. yay.
    Jan 2019
    84 Honda Prelude
    Washington
    Project is dead. '83 transmission does not bolt up to an '84 block.
    I seriously doubt i will be able to find a transmission for an ET2 block.
    Why not have an adapter plate fabbed up?
    Jan 2019
    84 Honda Prelude
    Washington
    I'd really prefer that to be the last resort. But yes, it is possible. I would definitely outsource that job though.
    Jun 2010
    What about using the 84 bellhousing on the 83 gearbox?
    Jan 2019
    84 Honda Prelude
    Washington
    Its possible, its just a matter of getting my hands on one. Out of all the yards I called, no one has a transmission. Might have to go farther than my local ones. I did see a motor on ebay but I asked the seller some questions and he hasn't gotten back to me. May be a riskier option there. I'll keep hunting locally.
    My other option is taking this non-running car with the right transmission, but I don't want to take on another parts car.
    I'm sure one will come up eventually.
    Have you used Car-Part.com--Used Auto Parts Market to search all the junkyards around your area.
    Jan 2019
    84 Honda Prelude
    Washington
    OOF. There's literally a local junkyard that I did not call that popped up on that list from car-part.com. The three junkyards within 15 miles to me just throw these cars away...
    I already ordered a JDM engine and transmission and it should be here next week. I shouldn't have to rebuild this one...
    It would have probably came out to the same price if I just got a transmission from a junkyard. Oh well.
    Jun 2010
    Same with yards around here. Hilltop, which is a big Honda/Acura yard, doesn't even have any older than 1990.
    Jan 2019
    84 Honda Prelude
    Washington
    Good news, the motor and transmission I bought a week ago were in good condition. The transmission bolted up and everything is mounted correctly. I'm going to be turning some bushings for the shift fork where the linkage bolts on tomorrow. The rest that's left to do for this swap is to install the pedal assembly, wiring the reverse lights, and neutral safety switch.
    Then putting the car back together will be fun : )
    Jan 2019
    84 Honda Prelude
    Washington
    The car is mostly all put back together. The automatic driver side axle does not seal up at the transmission. I took the seal off of the old automatic and noticed the ID was smaller than the ID on the manual seal. Now I have to wait around for another CV axle... The first one I ordered months ago didn't even pivot around so I returned it.
    Guess this project will be done next week.
    Jan 2019
    84 Honda Prelude
    Washington
    Ok well I'm almost done, but now I've got more problems in the way.
    First, the starter is not engaging with the flywheel. I'll have to pull it out and see if its popping out, and if it does I'm big time screwed.
    Next, the reverse lights are always on, even if the switch is plugged in. At least I got the wiring for the starter correct... maybe. I didn't have access to a multimeter to do further troubleshooting than that.
    What I did for the wiring was solder the thick black wires, and the green wires together. This connector was at the automatic shifter.
    Its always something isn't it...
    Jun 2010
    There are two wires right next each other in the plug. A yellow and green/black stripe. If your looking at the connector on the side the wires come out, they are the 2nd and 3rd on the bottom row going left to right. Pull those two out and separate them. Everything else gets bound together. Those two are the wires for the reverse lights.
    I did the same thing when I swapped mine, reverse lights stayed on.
    Jun 2010
    This is what mine looks like. My reverse light dont work because I have those two wire separated and just never got around to wiring them to the switch on the trans lol
    https://imgur.com/a/lzYl17U
    Is there a special MT starter for those like there is for the Accord?
    Jan 2019
    84 Honda Prelude
    Washington
    All the bolt patterns are the same, and part numbers on 2 of the starters I have are the same. I will have time to work on this car by Thursday, or I can try to work some time in during the days before that.
  1. Which is better a Manual or Auto?
    By BKKloppenborg in forum Performance
    Last Post: 04-12-2004, 05:09 PM
  2. Manual Vs Auto?
    By Red88Hatch in forum Interior & Exterior Care
    Last Post: 08-28-2002, 03:06 PM
  3. Replies: 2
    Last Post: 07-05-2002, 03:37 PM
