Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 131
Thread: Megajolt conversion
  1. #51
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: Megajolt conversion
    The two wires from the stock coil the blue and black with yellow stripe wire what are those hooked up to
  2. #52
    Jun 2010
    All that is still as is. Didn't cut anything or remove any stock components yet in case the edis didn't work. All I did was unplug the two connectors from the coil when I was testing the edis. Well that and plug wires of course.
    Right now it's back to stock cause I had to drive it to work today.
    Originally posted by ShiRen:
  3. #53
    Im guessing the relay needs a tach signal maybe from your new setup or you'll have to redo the relay somehow.
    Please don't bypass it unless just for testing. You want the fuel pump off if your motor isn't running.
  4. #54
    Jun 2010
    Nah, for sure.. wouldn't out right bypass it as a permanent thing, just testing things for now.
  5. #55
    Feb 2016
    Florida
    What powers the Edis
  6. #56
    Feb 2016
    Florida
    I see you have your shielded wire properly grounded to pin 7
    https://images.app.goo.gl/VffhDWmFU8mYgKar6
  7. #57
    Jun 2010
    First ran it off the battery to make sure it worked, then switched it to the wiper fuse. That one has good power and is switched to the "on" position
  8. #58
    Feb 2016
    Florida
    I assume as long as you got 12 volt that should be good. I use the original coil Black and Yellow wire for my power
  9. #59
    Jun 2010
    Assuming blue wire is ground?
    I just grounded the edis and mj in the battery. Seemed logical lol
    Would using the power wire from the stock coil basically trick the pump relay?
  10. #60
    Feb 2016
    Florida
    Possibly it may need to see the power coming from the coil wire. And that blue wire is your RPM signal on fuel injected model
  11. #61
    Feb 2016
    Florida
    I'm wondering if you got that shielded jacket grounded properly on pin 7. I kind of went through the same deal setting up mine. Those wires are real sensitive and can pick up signal real easy and cause a misfire
  12. #62
    Jun 2010
    I dont think I do have it setup right. I have the vr sensor wire shielded and is grounded to the body on the sensor end and ran into pin 7 on that end but did not run that into the main ground. I'll have to fix that.
    Good looking out.
  13. #63
    Jun 2010
    Pretty sure the carb and fi use the same coil setup. The wire colors and everything are the same in any case.
    So blue wire is tach signal.
  14. #64
    Feb 2016
    Florida
    Yeah try that out.
  15. #65
    Feb 2016
    Florida
    Yes I know on a blaster coil the blue wire goes to the negative side of the coil
  16. #66
    Jun 2010
    Ok so.. if I ran a wire from the tach out pin on the mj unit to that blue wire, that should in theory send a signal through said wire into relay?
  17. #67
    Feb 2016
    Florida
    Possibly after reading through knife mine's set up apparently that tach signal has something to do with the fuel pump relay
  18. #68
    Feb 2016
    Florida
  19. #69
    Feb 2016
    Florida
    The stock fuel pump relay,well for EFI, looks at the neg side of the coil to confirm the cars running that might be what you need.
    This
  20. #70
    Jun 2010
    Well yea, there it is. So I need to get a tach signal into the relay.
    Knife doesn't say what he did to fix that issue though, I wonder what he did.
  21. #71
    Feb 2016
    Florida
    I know I wish he would have said what he did at the end
  22. #72
    Jun 2010
    I'll try the tach out on the mj unit the next time I get to mess with it.
    Thanks to all you guys for the help. 👍
  23. #73
    Feb 2016
    Florida
    i hooked up the wire that i had goin to the coil, i think it was blue, to the 'tach out' from the MJ, and now the tach and the fuel pump work.
  24. #74
    Jun 2010
    Many tachometers can accept the signal emitted from the Tach Out on the MJLJ module. This Tach Out signal provides a 12V pulse for every ignition event. You may use this to provide the signal to compatible tachometers, or to provide a signal to a separate Engine Control Unit, data logger, or other device which requires this signal.
    From the instal guide. May just work.
  25. #75
    Jun 2010
    Lol posted at the same time
  1. 2ndGenGuy's '81 Hatchback MegaJolt Lite JR Conversion
    By 2ndGenGuy in forum Project Central
    Last Post: 02-25-2015, 04:32 PM
  2. ItzDave's Megajolt thread!
    By itzdave in forum Carburetor Tech
    Last Post: 10-13-2011, 08:22 PM
  3. OBD-I conversion
    By Nik247 in forum Performance
    Last Post: 07-26-2010, 12:49 AM
  4. E85 conversion kit
    By nswst8 in forum EFI Tech
    Last Post: 12-14-2009, 12:24 PM
  5. HID conversion
    By Blaaz in forum Classic Honda Community Chat
    Last Post: 07-06-2007, 09:31 AM
