Results 1 to 7 of 7
Thread: Transmission
    Nov 2017
    Transmission
    How do you guys check your transmission fluid. I have an 89 LXi automatic that I bring up to normal temp turn the engine off and check the dipstick. It might just be me but that dipstick is a pain to read. Does anyone do it differently?
    LXi User AC439's Avatar
    86 LXi
    FL
    Re: Transmission
    I have a 86 LXi auto. To check ATF level, engine must be off and car on level ground. I do not warm up the car to normal.
    Unscrew the ATF dip stick, wipe clean with towel and insert it back but NO screwing it into the thread. Then take it out and read level. Afterwards, put the dip stick back and screw it all the way back to seal.
    If need topping up, use only Honda ATF.
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    Re: Transmission
    AC439
    This is correct and the only way.
    1988 Honda Accord LSDX-I
    Nov 2017
    Re: Transmission
    thanks
    Nov 2019
    Re: Transmission
    Is there any particular type of Honda ATF that is made for 1989 LXis? Or is it a universal fluid?
    86 LXi
    FL
    Re: Transmission
    Go to Honda and buy ATF. I have not heard of any particular type for a specific generation. According to the parts guy, this should be universal for all Honda AT. I'm not sure about the CVT tranny though.
    The current Honda ATF is DW-1.
    I have been exclusively using Honda brand ATF for my 86. Never have a problem.
    Nov 2019
    Re: Transmission
    Quote Originally Posted by AC439 View Post
    Thank you, I will check it out!
  1. 1988 HONDA ACCORD Transmission - Manual Transmission, (2.0L, 4 cyl), FI eng
    By JoshydillingerLX in forum Classic Honda Community Chat
    Last Post: 11-01-2014, 02:46 PM
  2. Transmission Help
    By SladeHonda in forum 3geez Accords
    Last Post: 04-17-2012, 12:34 PM
  3. transmission help
    By henrymca in forum Performance
    Last Post: 11-07-2006, 01:00 PM
  4. What should I do about the transmission?
    By kahsperr in forum Performance
    Last Post: 01-05-2003, 08:22 AM
  5. transmission
    By juiquan in forum General Engine Swaps
    Last Post: 12-05-2002, 07:05 PM
