Would a Vtec controller work on our cars for adjustment of the diffrent fuel curves?? My friend with an h22 accord has one to sell me but is not sure if it would work!!!!:super::badass:
Is it worth the $$$ when it even says VTEC in the title for a A20A?
Its used also for adjusting fuel curves!!! So, if i can adjust my fuel that would make car run better and faster!!!! You dont know very much about shit do you???
Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
I have never asked or researched what a VTEC controler does, but doesn't it just activate the VTEC mechanism and nothing else?
no, it hooks up to the MAP sensor and the Vtec soilnoid so you can adjust fuel ratio and @ what point the car switches from low rpm cam to the high rpm cam!!!
if youre refering to the apex'i V-AFC, then yeah you can use the apex'i S-AFC to adjust your fuel curves... its the same as the VAFC, only for cars without vtec... i imagine the VAFC wouldnt even work right...
pretty spendy though... your money is probably better spent on a cam or some other fun goody
Its not the Apexi one!! Its the same thing but you just dont have a vtec thingy!!!!
The VTEC controller controls the basic engine management.. You can also program your VTEC lower and your Turbo's management (at least my friends can)
But if you are adjusting your fuel curves wouldn't you [for your best interest] have to buy a A/F Ratio Gauge as well?
I already have one thats how i know that i am running lean!!
well, you can try it, and tell us later.
Yeah man.. If this all works out give us a shout.. Maybe a new technique us 3geez can use
Hell ya!!
