Car runs fine once over 1500-2000rpms, but wont hold an idle and stalls out. Don't know much about it, where should I look first? It's a 5-speed with very high mileage and has been sitting dormant for about a month.
does it happen all the time hot and cold ! if so check for the idle mixture screw ( the AF screw ! ) may be it fell out or so loose !
MIKE
it happens all the time, i already tried fooling with the idle adjustment screw, makes no difference.
You may have a vacuum leak. Did you check your hoses? I know its a bitch to troubleshoot.
_M
i didn't say idle adjustment screw ! i said the idle mixture screw ! ( Air fuel mixture screw! )Originally posted by seancornelis
check this how to for it !
http://members.fortunecity.com/accordex87/carb.htm
http://members.fortunecity.com/accordex87/CarbSetup.htm
if no help search for a vacuum leak !
MIKE
