Results 1 to 9 of 9
Thread: new to me 89 Lxi where do i start?
    May 2019
    Smile new to me 89 Lxi where do i start?
    long story short, i have been given an 89 Lxi with 137k miles on it by my grandma, it was my grandfathers and he passed away about 6 years ago, the car has been sitting for atleast that long, if not longer.(i would guess atleast 7 if not 8) its in mint condition. no rust no leaks(yet..) and the car has been in a garage on a battery tender. the gas was drained when it was stored, i simply put some gas in it today and tried starting it. after about 5 mins or so of cycling the fuel pump and trying to start it, it finally popped off and sorta ran. sounds and feels like its missing on atleast 2 cylinders ive got a wire set on the way(broke 2 of the 4 trying to take them off) and new spark plugs which will be here Wednesday. short bit on me, im very mechanically inclined(i've built a dozen or so 500+whp subarus) but know NOTHING about hondas let alone one of this age.. that being said, this is where you guys come in! What are some common issues or things i should check before i go any further? i'm suspect of the injectors because of how long the have been sitting without any fuel in them to keep them from rusting/corroding internally. with our subarus we could pull them and use a 9v battery to test them to see if they click, that okay to do here? otherwise where can i look for replacement injectors online? i would feel much better with some cleaned/remaned injectors..
    any and all help is greatly appreciated. thanks in advance!
    -Ryan
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: new to me 89 Lxi where do i start?
    replace the fuel filter too
    May 2019
    yup! that was also on my list. thanks for reminding me.
    Feb 2016
    Florida
    Yeah it's been sitting for so long It probably just need some fresh gas to get through it. But if you remove your fuel rail there should be little filters that go down inside the injectors that you can pull out and clean
    May 2019
    ill try that Wednesday after i get the fresh plugs and wires on it. thank you.
    Sounds like a wonderful find! Congrats! If it's as good as you describe, you probably won't need to do much. Just get it running decently well and after a few tanks of gas, it should be back to its old self. Enjoy the handling. These are among the best suspensions ever made. You'll want to give the car a thorough going over. Look for leaks, cracking rubber, etc. You probably won't find a lot to do, other than drive it and enjoy of course.
    Post pics soon for us.
    May 2019
    ill be sure to post some pictures =) it pretty much look just like yours, same color
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    And if its been sitting that long , once its running , do a cam belt and associated bits
    LX User Honda#1's Avatar
    1983 Accord LX hatch carb'd; 1986 Accord LX-i hatch
    Midwest
    You got this right! Definitely replace the belts, anything rubber based that is needed to run the car replace. Sitting that long, dry rot. You should also flush out all the fluids.
  1. hot car won't start
    By snoopyloopy in forum EFI Tech
    Last Post: 02-23-2010, 09:37 PM
  2. Car won't start
    By TJX in forum EFI Tech
    Last Post: 12-12-2006, 12:15 PM
  3. 86 accord start then died then wont start again
  4. Replies: 4
    Last Post: 12-30-2003, 10:45 AM
  5. Won't Start
    By infecto in forum 3geez Accords
    Last Post: 04-25-2003, 11:53 PM
