Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: Wilwood Front Caliper Kit
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Wilwood Front Caliper Kit
    The difference between the dx brakes and the lxi brakes is fairly marginal, most importantly they will cool better, but if you have rear drums then you will experience brake fade in the rear first. The prop valve is the most labor intensive part to install, but if you want to do that then I would look at a much better set of brakes for the front, like integra or porsche 911 calipers.
    Quote Originally Posted by bscanlan View Post
    They are quite fetching when installed
    Attachment 11076
    Im curious how you will like them.
    I dont know how fixed caliper and non ABS will work.
    I know my newer cars the ABS is doing something all the time to keep the pads centered and mitigate pad kick back. My Jeep pulses the brakes when the wipers are on to keep the rotors cleaned off.
    bscanlan's Avatar
    Jul 2012
    1988 Accord LXi Coupe
    Amherst, Ohio
    I guess we will see!
    1989 LXi Hatchback - Napster
    1989 LXi Sedan - sold 😒
    1988 LXi Coupe - Old Skool
    2023 Chevy Bolt EUV - DD
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    They will probably just squeak like mad, but thats the charm of driving a car with fixed calipers. AFIK my type R does not use the abs unless it needs to... its brakes are noisy, but I kind of like it, unlike the squeak from your wifes crossover which has been riding on the wear indicators for 4 months.
  1. Wilwood brake install
    By im_the_snoman in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-11-2015, 09:01 AM
  2. Front caliper not grabbing
    By SkateK610 in forum 3geez Accords
    Last Post: 10-08-2011, 05:16 PM
  3. Front Caliper Rebuild
    By vongiese in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-21-2007, 07:10 PM
  4. Front Caliper Set - Good buy?
    By Estimated Prophet in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2007, 12:32 PM
  5. URGENT ASST. PLZ! Brake Caliper Frozen on Caliper Pin!
    By ascender in forum 3geez Accords
    Last Post: 08-03-2003, 07:38 PM
