Results 1 to 5 of 5
Thread: loose venturi?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    loose venturi?
    how do i tighten the first barrel one, do i have to take the top hate of the carb off?
    LX User mindlos's Avatar
    97 Prelude Base
    Minneapolis, MN
    97 Dodge Neon
    Athens AL
    what does A20A1 mean by "and to remove it from the carb you will have to drill the rivets out to gain access to one of the screws."
    cant i just remove the choke to get to it??
    thanx
    97 Prelude Base
    Minneapolis, MN
    There is one more screw behind the plate (basically inside) that still holds the module onto the carb. You wount be able to get it off with just those two screws outside so you gotta remove the plate hence drill out the rivets. There's no easier way to get the rivets off. You might need some nuts and bolts to put the plate back on if you still keep the module.
    shepherd79's Avatar
    Falling Waters, WV USA
    to get access to prmary vinturi screw you will have to remove choke.
  1. Replies: 21
    Last Post: 12-02-2018, 03:41 AM
  2. Variable Venturi VS. Fixed Venturi carburetor?
    By dat in forum Carburetor Tech
    Last Post: 03-16-2008, 06:41 PM
  3. Primary Venturi Loose
    By TheAsianInside in forum Carburetor Tech
    Last Post: 09-02-2004, 06:56 PM
  4. 86 carb venturi spraying gas
    By platinumhandz in forum Carburetor Tech
    Last Post: 04-27-2003, 07:21 PM
  5. tighting first barrel venturi help
    By Mantis88LX in forum Carburetor Tech
    Last Post: 04-24-2003, 01:23 PM
