My PCV Valve is fouled. Easy to replace? Nope. Plenty of posts on how difficult these are to get out without breaking the lower tube, especially after being in a hot engine for 33 years. All true. Applied a bit of light weight oil and allowed it to seep in between the PCV Valve and tube for a long while. Then made sure to get the engine nice and hot to soften the tube before attempting to remove the valve, but no joy. The PCV Valve spins nicely in the tube, but the lower barb has bitten into the tube and it will not budge upwards. I can already see that the top of the tube is cracked, so it too now needs to be replaced.
Considering that the lower tube is beyond obsolete, does anyone have a suggestion for a substitute tube/hose that has worked well?
I would also appreciate advice how swap out the dang tube once I find something that will work. It is not visible from the top or sides. I have not yet raised the car and removed the splash shield, so maybe it is not as bad as I fear.
Thanks,
Blue
