Results 1 to 14 of 14
Thread: Update on my 83 Project
    DX User dedens's Avatar
    1983 Accord
    Portland Oregon
    After a few summer adventures in the 1983 Accord, it is time for the fall/winter project to get started. A local shop is building my EK1. I used some of the specs listed on the Moster EK1 Thread. I have an EL head but decided to use the stock CVCC head for this project. I plan to install the new motor in late October.
    For those interested...you can follow my project on Facebook and a GSite that I have setup.
    A few specs:
    • Block bored .20 over
    • New pistons, rings, and bearings
    • Crank to spec and polished
    • CVCC Head with custom cam grind Block bored .20 over
      CVCC Head with custom cam grind (Advertised Lobe 280/Advertised Duration 270/Lobe seperation 110/Overlap 44)
      New valves, seals, and stiffened valve springs
      Head ported/polished
      Lightened flywheel
      Stock manifold ported polished
      Full Stainless Exhaust with 'Emissions' delete
      Weber 38 carb
    • New valves, seals, and stiffened valve springs
    • Head ported/polished
    • Lightened flywheel
    • Stock manifold ported polished
    • Weber 38 carb
    Re: Update on my 83 Project
    Legit! Me like!
    Oct 2019
    Super cool man! Maybe I'll catch you at the Old School Meetup? Sounds like you're from the NW too https://www.facebook.com/events/767860303557741/
    1983 Accord
    Portland Oregon
    I should be getting my upgraded / rebuilt engine next week. These past weeks, I have been tearing things down and gathering parts.
    In a addition to the engine upgrade, I am:
    • Installing a front 'Big Brake' upgrade (Calipers/Rotors) from 1988 Accord LXI. This includes all new wheel brearings and hubs
    • new control arms, bushings, and mounts.
    • Turned my PS Rack into a Manual (this was a fun project)
    • Making a few adjustments to the rear disk setup (from a 1985 lude)
    • Installing 2nd Gen Civic BC Coilovers
    UPDATE: Photos of the PS delete on a refurbished rack.
    1983 Accord
    Portland Oregon
    Seadude...I live in Portland Oregon. I am planning to attend the old school reunion 2020.
    1983 Accord
    Portland Oregon
    Late UPS delivery last night. Super stoked to get these fitted and installed. Will have to do a little 'sleeving' but nothing too crazy.
    They sent you knuckles too? Wow!
    Have fun with them.
    1983 Accord
    Portland Oregon
    Those are my stock knuckles. I pressed the bearings out, cleaned, painted, and reinstalled new bearings and seals. Below are pics of the final fitment and mounting. Unfortunately, the 88 LXI calipers don't fit even though the rotors fit fine.
    No pics?
    1983 Accord
    Portland Oregon
    For some reason the links to the photos were removed from the Post. Let's try this again.
    As a side note. We will be fabricating strut bars for the front and rear. I'll post when we get to that point.
    https://photos.app.goo.gl/irwWaoFawJEshLN59
    Oct 2019
    Wow. Cool flicks. Couple quick questions:
    1. What is the tool you used to press in those new wheel bearings / hubs? I had to take mine to a machine shop.
    2. What is all the custom metal and weld bead/etc in your BC Coilover photos? I can't quite make out what you used it for.
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    This looks fantastic! Makes me want a 2g to play with
    Nov 2019
    1983 Accord Hatch
    Vancouver, WA
    Quote Originally Posted by seadude View Post
    We used a standard front wheel bearing press tool kit
    We had to weld sleeves onto the coilovers to make them fit an accord knuckle/spindle. These are not a direct fit and require modification to make them work.
    1983 Accord
    Portland Oregon
    Howdy folks...I have been updating my website (click here) but have neglected to post to this site. My 83 accord is back together with the following upgrades: I am very happy with the end results. The upgrades far exceed my expectations. She rips with the engine, intake, and exhaust upgrades.
    • New lower and top end, custom cam grind, and head work including stiffer valves.
    • New suspension and subframe bushings, wheel bearings, hubs, and such
    • Rebuilt steering rack
    • Custom fit BC Coilovers on all 4 corners
    • Upgraded front brakes to 3rd generation Accord
    • Front and rear custom made strut braces
    • Installed 02 bung and AF gauge
    • Custom RamAir filter
    • Other bits and pieces replaced as need
    Final Cam Specs:
    https://photos.app.goo.gl/crZN6RGagBJzGTnd9
    Engine update Photos:
    https://photos.app.goo.gl/Nv8gd3YvBCujThS19
    https://photos.app.goo.gl/JS18wopffSWqWNdj8
    https://photos.app.goo.gl/SqEKBUC2mHznoj2y6
    https://photos.app.goo.gl/sB3C1wETkzKy6x587
    https://photos.app.goo.gl/9WNgdrAGwdgDBB7WA
    https://photos.app.goo.gl/UmVdH2WyzJFPWxRE8
    https://photos.app.goo.gl/cC6iVygoKZpcUZkT9
    https://photos.app.goo.gl/5rbTH6yaEzZDqjE99
    https://photos.app.goo.gl/RgSucuR9d3btYSgCA
    https://photos.app.goo.gl/RTRDQgAmQqv287gQ9
    Engine update Videos:
    First Startup: https://photos.app.goo.gl/2GFVqMxjYXC7H6is8
    Second Startup: https://photos.app.goo.gl/9jUEQSLZYsmTrsvP6
    Suspension update Pictures:
    https://photos.app.goo.gl/PLG3F4KEfA6aaGKq6
    https://photos.app.goo.gl/uD8NfMzkKzD8spPY6
    https://photos.app.goo.gl/8Jn2gJH2vn9cNTpY7
    https://photos.app.goo.gl/QoiKtb2xwwv7fmgy9
    Back at home and work.
    https://photos.app.goo.gl/M9gaXVwYDvDJpEXh7
    https://photos.app.goo.gl/ZmFWx3pUwtjFnwHm9
  1. Project Milenko (Update Thread)
    By Juggalo88Accord in forum Classic Honda Pics & Videos
    Last Post: 08-22-2010, 03:34 PM
  2. update: turbo accord project
    By bobafett in forum Classic Honda Pics & Videos
    Last Post: 02-06-2008, 04:19 AM
  3. just an update on the accord project
    Last Post: 03-11-2007, 07:45 PM
  4. Project Clear/Red Update
    By bullard123 in forum Interior & Exterior Care
    Last Post: 04-14-2005, 08:28 PM
  5. Update: Project NA B20A
    By AccordSi in forum Performance
    Last Post: 08-21-2002, 11:18 PM
