Results 1 to 10 of 10
Thread: Stud Pattern !
    LX User Shifty's Avatar
    Jan 2003
    87 Honda Accord Si PGM-FI ;)
    Canberra, Australia
    Question Stud Pattern !
    Anybody know the stud pattern on the 87 ? Well a honda prelude 96 stock rims 16" fit ? and does anybody know where to get clear lights (tail, corner,etc ).
    still not clean, Still Not Clean ,STINK OF FAILURE STILL ON ME
    Jan 2003
    1987 honda accord
    toronto ontario
    bolt patern is 4 by 100mm
    aslong as the prelude rims have 4 bolts they will fit
    as for the lights you have to make them no one sells any.
    lates
    racer x
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: Stud Pattern !
    Not just any 4 bolt honda rim will fit on your car. You cannot use any rim that is not EXACTLY the same, not all 4 bolt pattern rims are the same, if the bolt pattern is not the same, NO GO.
    The 3rd gen accord uses 4x100mm bolt pattern
    4th, 5th, & 6th gen accords (4bolt) and 92-96 preludes all use 4x114.3mm bolt patterns. Your best bet is 94-2000 integra alloys or any civic rim that you like (99-00 SI rims look good).
    PS, no one makes clear tails or corners. I recommend that you search in the appearance section because that topic is talked about all the time in that section. In the FAQ section of the board you will find a how to for making you front bumper turn signals clear (unless you have a hatchback).
    Now I d
    Jan 2003
    1987 honda accord
    toronto ontario
    I had no idea that all honda 4 bolts were the same sorry for the misinfo.
    racer x
    Central California
    Hey it's cool, I figured my post would help you to
    Now I d
    Jan 2003
    1987 honda accord
    toronto ontario
    Speaking of bolt paterns any on redrill rims to fit 4x100?
    racer x
    Central California
    No has done that, you really woundn't want to do that anyways. YK86 had his hubs redrilled or something for a different bolt pattern. But from what I understand is was a big pain and I believe he'd never do it again. You could always pm him on the matter.
    Jan 2003
    1987 honda accord
    toronto ontario
    Well the rims are 4x114mm so I was thinking that to lenghen the studs holes by 14mm would not be to hardcore.
    racer x
    2.0Si User Grant2k's Avatar
    can you do them all evenly enough to keep the wheel balanced?
    Jan 2003
    1987 honda accord
    toronto ontario
    They would be done at a shop so I think so I think he was going to make a template from a roter with no studs and clamp that on the rim.
    racer x
  1. Bolt Pattern for Head
    By mynizzle209 in forum 3geez Accords
    Last Post: 03-11-2005, 07:52 PM
  2. bolt pattern
    By 89accordex in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-29-2004, 11:27 AM
  3. Lug pattern?
    By NotFast in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-14-2004, 06:52 PM
  4. What is my bolt pattern
    By Magny in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-24-2003, 04:58 AM
  5. bolt pattern
    By 92 ex-r in forum Classic Honda Community Chat
    Last Post: 05-18-2003, 09:36 PM
