Results 1 to 3 of 3
Thread: starting problems
    Jan 2003
    tan 88 LX-i sedan
    East Lansing, MI
    Unhappy starting problems
    okay here's my situation. My car's a pain to start in the cold weather up here (from about 10deg. to -15deg.) Now I just had the battery checked so I know that's not the problem. When I turn they key I just hear a clicking sounds or sorts (very quiet) and it doesn't even turn. Then I'll sit there in my car for about 10 minutes trying it every once in a while and then it'll finally start. And oh yeah, it only has this problem when i try to restart the car within about 3 minutes of it running. Thanks for all of your comments.
    My mods:
    those red emblems
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Sounds like a starter, or possibly the battery cables. At the rarest it might be the ignition pigtail...but don't worry about that till you check other things first.
    1988 Accord LXi Sedan
    Custom Cold Air Intake -- Custom Exhaust -- Neuspeed Springs -- ACT Stage II Clutch
    Alpine 9815 -- MTX 2300X -- 2 JL 10W3V2's
    Oct 2001
    87 Accord EX , 5spd , Manual
    i would check the starter's ground it 's a very thin wire and does this big problem ! clean the end of it , clean batter terminals , check the ground and clean !
    MIKE
  1. starting problems
    By daniel70ca in forum 3geez Accords
    Last Post: 11-21-2008, 10:18 PM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. Starting problems
    By Underdog in forum 3geez Accords
    Last Post: 08-22-2004, 11:44 AM
  4. Starting Problems
    By uneek in forum 3geez Accords
    Last Post: 02-19-2003, 04:47 PM
  5. car has problems starting
    By socal3rdgen in forum 3geez Accords
    Last Post: 12-28-2002, 08:54 PM
