Results 1 to 14 of 14
Thread: Trying to adjust door
    LXi User AC439's Avatar
    86 LXi
    FL
    Trying to adjust door - @#$%^& !
    Switching gear a little bit here. My driver door is sagging slightly and the door doesn't close smooth. I read up threads and trying to adjust the hindge.
    First of all, there is no way a tool can be fitted in to loosen the hindge bolts without taking off the fender. I started taking off the fender bolts and they were rusted. I cannot take the top middle one off, the thread is bad from rusted and it just rotates. The bolt is loose and spin but will not come up.
    So option 1 is out (adjusting the hindge). I thought maybe I can adjust the striker a little....
    The two big philips screws are on crazy tight. I broke two philips head trying to loosen them.
    Any other ideas ?
    Re: Trying to adjust door
    l don't know about Hondas, but on Chevy trucks the hinge bushings wear out and allow the door to sag. Hinge pins and bushings are less than $10 each on eBay. Of course if you can't get the fender off, you may be stuck.
    And for the strike plate screws, you need one of these:
    https://www.harborfreight.com/6-bit-...ase-64812.html
    86 LXi
    FL
    I have been thinking about this tool after I posted. Was around HF earlier today with the wife and I chose to keep silent and keep driving.......
    Out of curiosity, how are you trying to adjust the hinges?
    86 LXi
    FL
    I have been unable to get to the bolts of the hinges. I cannot take the fender off. I tried to tap the pin (the limit the excess swing) out but it still would not give enough room for any tools to get to the hinges.
    The door only sag 1/8" (maybe even less) so its hitting the strike a little bit. But I'm unable to loosen the strike screws either.
    I will try to sneak into HF to get the impact screw driver.......
    l ask because they don't look adjustable to me. I think you're likely to make a mess if you try.
    86 LXi
    FL
    I think its adjustable per FSM page 21-14 therefore I am thinking giving it a try......
    I pulled a few bolts from the lower fender and pulled it back a little to work on it. I had removed the mud flaps a few years prior.
    Quote Originally Posted by AC439 View Post
    Wow! Is there anything the manual doesn't cover!?
    86 LXi
    FL
    Yup, the manual doesn't tell me where GND-12 ground location is. Also, Chilton has better schematic diagrams. FSM's schematic diagram is only spotty and hard to get a complete picture.
    86 LXi
    FL
    Really ?! Downloading......I wasn't aware of this one.
    Download completed. I bet the author of this manual is a different person than the main FSM. GND-12 in the main FSM is G201 in the electrical manual.
  1. Replies: 2
    Last Post: 12-04-2017, 04:30 PM
  2. 2 door and 4 door model door handles interchangeable??.............
    By detroit313 in forum Interior & Exterior Care
    Last Post: 04-27-2007, 05:22 PM
  3. Replies: 2
    Last Post: 09-07-2004, 04:55 PM
  4. Where do you adjust RPM Scale?
    By AccordAddict in forum EFI Tech
    Last Post: 08-14-2004, 06:34 PM
  5. How to= Adjust konis?
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-25-2002, 05:19 PM
