Results 1 to 4 of 4
Thread: High idle with idle adjust screw seated
    DX User 01civy's Avatar
    Aug 2010
    01' civic, 89' Cord
    The Sticks, CA
    Working on an 89’ accord LXi with an A20A3 motor.
    I’m trying to set the idle so I can set the timing but the idle screw on the throttle body is as far in as it will go. Not really sure why it’s doing this.
    Any help is much appreciated!
    Re: High idle with idle adjust screw seated
    Check for vacuum leaks.
    Quote Originally Posted by 01civy View Post
    make sure the throttle cable has slack in it at idle. Some people adjust the idle that way and you should not.
    LXi User AC439's Avatar
    86 LXi
    FL
    Don't forget to check the o-ring on the idle adjusting screw. I had the 0-ring broken before and the air leaking inside from around the screw making the idle high.
  1. High Idle with no way to adjust it?
    By mushroom_toy in forum EFI Tech
    Last Post: 10-04-2009, 08:37 AM
  2. How to adjust engine idle
    By Connor_LX-i in forum Classic Honda Community Chat
    Last Post: 06-17-2009, 12:41 PM
  3. how to adjust fast idle screw?
    By skyca5 in forum 3geez Accords
    Last Post: 08-16-2004, 12:05 PM
  4. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
  5. Warm idle adjust?
    By agelder in forum Carburetor Tech
    Last Post: 05-24-2003, 07:49 PM
