Results 1 to 3 of 3
Thread: Can't seem to figure out why 85 isn't running.
    Jan 2020
    1985 Accord/ 1987 CRX
    PNW
    It kept stalling when i idled so I replaced the fuel pump, both filters, and my air filter to see if that would help, it didn't. Then i replaced the distributor cap and rotor then tested for spark and it was good. I parked it for a while and when i came back to work on it a month later the carb was flooding. i figured that was the issue the whole time so instead of rebuilding these atrocious keihin garbage fires i did a weber 32/36 swap, then found a vacuum leak i missed post swap because of the monsterous EVAP system on these things. I am currently replacing the fuel tank with a new one because it was gunked with sludge and the fuel filter by it was bricked but because of the car's behavior and good fuel pressure i truly don't believe that was it. Any thoughts?
    Nov 2017
    Re: Can't seem to figure out why 85 isn't running.
    Get it tuned properly, maybe go down in jet size, and make sure you have good sealing between the carb and adapter plate. Use loctite or lock washers on all fasteners
    All carbs need good clean fuel. Finish getting that cleaned up, new spark plugs NGK and see what you have there.
  1. Figure I should say hello
    By Ralphyboy in forum Newbie Introductions
    Last Post: 03-16-2009, 04:50 AM
  2. figure this out
    By b20a86lude in forum 3geez Accords
    Last Post: 03-01-2007, 08:57 AM
  3. Help me figure this out.....
    By kicker1_solo in forum Classic Honda Pics & Videos
    Last Post: 09-15-2003, 10:05 AM
  4. Maybe you all can figure this out
    By TigaMan10 in forum EFI Tech
    Last Post: 07-30-2003, 01:25 AM
  5. cant figure out what lever does...
    By johnwc723 in forum Classic Honda Community Chat
    Last Post: 02-26-2003, 08:26 AM
