Results 1 to 5 of 5
Thread: gauge help please
    Feb 2003
    87 accord lxi
    roc, ny
    gauge help please
    i just got a new oil pressure, ammeter and temp gauge. i have questions for all of them. what is the size of the oil pressure fitting on the block and where is it(a picture would help alot)? i know its by the oil filter. where do i install the ammeter? it says to install it to the starter, but i see no point in that. and finally, do i install the temp sensor into the factory sensor port and run with out it? or is it just a fan switch? is there a temp sensor in the block as well? b/c i dont want my car to run rich and have a high idle. all your help is appreciated much.
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    are all the gauges electrical?....
    the ammeter needs to be rated higher that alternator output and is connected in series between the + of the battery and alternator,..dont earth it or you'll blow it.......if unsure get an auto electrician to put it in.....
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Oil pressure fitting I thought was a -4an, but possibly 6....it sits atop the oil filter housing, sticking up. Not entirely sure on the anmeter. The temp gauge (depending on what they gave ya) can go to the single wire sensor on the t/stat housing without screwing up any of the a/f mixture and other computer related things.
    1988 Accord LXi Sedan
    Custom Cold Air Intake -- Custom Exhaust -- Neuspeed Springs -- ACT Stage II Clutch
    Alpine 9815 -- MTX 2300X -- 2 JL 10W3V2's
    Feb 2003
    87 accord lxi
    roc, ny
    ok, the ammeter i get, but i dont understand what you are talking about with the temp guage. its a mech gauge as well as the oil pressure gauge. for the temp gauge, am i supposed to connect it to the port in the bottom of the radiator or somewhere else? because i know there is already a sensor in the bottom of the radiator, but i dont know if it is for the fans or for the ecu.
    Jun 2002
    do as BoredRec suggested, remove the single wire sensor on the thermostat housing,put in a t-fitting,(if you want to use original temp gauge as well), and adapters to take the sensor and mechanical gauge hose fitting,.....do the same with the oil gauge.
    The 2 wire sensor on the thermostat housing is for the ECU i think,not quite sure with your model....the one on the bottom of the radiator is for fans
  1. Gas Gauge
    By Fuzy Navel in forum 3geez Accords
    Last Post: 02-06-2006, 06:23 PM
  2. A/F gauge and Water Temp gauge
    Last Post: 02-29-2004, 09:29 PM
  3. Psi gauge
    By Morbid Intentionz in forum Trading Post
    Last Post: 01-05-2004, 10:17 AM
  4. need help with gauge
    By Dave-hid in forum 3geez Accords
    Last Post: 11-07-2003, 03:36 PM
  5. Gas Gauge?
    By foxracer22 in forum 3geez Accords
    Last Post: 07-20-2002, 06:26 PM
