Results 1 to 12 of 12
Thread: 88 LXi not starting, no fuel, GND pin voltage offset
    DX User jtb_116's Avatar
    88 LXI
    Detroit
    I'm having an issue starting my 88 lxi. I replaced the engine with one I rebuilt and have not been able to get it to start since. It cranks and has spark, but no fuel. The fuel pump does not come on unless 12 V manually applied to it. I also verified that the main relay works correctly when voltage is manually applied to the appropriate pins on it.
    I narrowed it down to the main relay harness connector. The IGN SW pin is not getting properly energized to start the fuel pump. I verified that the actual ignition switch is working correctly in each key position.
    IGN SW relative to the GND pin on the harness reads -0.5 V with key off and 0.6 V with key on
    IGN SW relative to the battery negative post reads the correct 0 V with key off and 12 V with key on
    GND harness wire reads 0.5 V relative to the battery negative terminal with key off
    I'm having trouble tracing the harness through the firewall into the engine bay. Is anyone familiar with where this wire would ground to in the engine bay. And what would cause the GND wire to have a voltage offset like this? I would think that if it was shorted it would just be 12 V. Any help is appreciated.
    Summary: GND wire in main relay harness has 0.5 V with key off and 11.5 V with key on. This is preventing the IGN SW from generating sufficient voltage to activate the fuel pump relay. Not sure what would cause this on the GND wire
    carotman's Avatar
    Montreal South Shore
    Re: 88 LXi not starting, no fuel, GND pin voltage offset
    The ECU will activate the main relay.
    Make sure you get voltage at the ECU
    88 LXI
    Detroit
    So I'm testing the harness for the main relay according to the FSM
    The pin 5 (IGN SW) gets 12 V if I check it relative to body ground or the battery. The issue is, checking the voltage between pin 5 (IGN SW) and pin 2 (GND), there is not 12 V because the ground pin is not at 0 V. Therefore there is not sufficient voltage to activate the relay which powers the fuel pump.
    So I'm trying to figure out what would cause the GND pin to not be at 0 V. And where the ground pin actually routes to in the engine bay.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I've traced the wires back before and your main ground for the main relay is on the side of the intake manifold. Try cleaning it up or adding a extra wire to that to the firewall
    Quote Originally Posted by jtb_116 View Post
    id suspect that there is a corroded connection and/or a damaged wire some place from the readings you are getting on the ground. if your battery is 12.7 volts at rest then less than 12 volts at the relay is a pretty good voltage drop right there.
    Someplace in the book there drawings of how the wiring harness routes thru the car and all the connectors.
    88 LXI
    Detroit
    Awesome, thanks. I'd bet when swapping in the engine I forgot to attach that ground. I'll update if that was it.
    Feb 2016
    Florida
    Yeah keep us updated on it
    The two main ones I can think of is battery negative to the case of the trans and the one from the valve cover to the front cover of the radiator. Either one of these is missing there is alot of trouble there.
    The one Shane pointed out has alot to do with the injectors its off theres trouble there.
    You may want for ow to run a separate ground from the relay post back to the battery just to get you going and get hat baby fired up.
    88 LXI
    Detroit
    Haven't had the chance to check the ground around the intake manifold yet, been raining everyday after work. Should be able to get to it this weekend though.
    I do know I have the ground from the valve cover to around the radiator attached.
    But even with a missing ground wire, the ground still shouldn't show positive voltage relative to the battery negative right?
    The only thing I'd be worried about with running a direct ground to the main relay harness is with the bad harness ground getting voltage I'd have to disconnect it and run a separate wire. If the bad ground is shared with other components, I assume those then will have issues.
    Thanks again everyone for help!
    88 LXI
    Detroit
    So finally had good enough weather to tinker around some more. Turns out, the FI harness ground was missing the bolt. I put one in and...no difference. Still have the voltage offset at main relay ground. I checked and less than 2 ohms between the FI harness and negative on the battery. IM and valve cover less than 1 ohms.
    Any other ideas?
    88 LXI
    Detroit
    So I finally solved it!
    You guys had the right idea with a ground not being connected. I traced the main relay ground back to the ECU and grounded the pin and it fired right up! I was ready to just run a ground to this wire and hope that I had no more issues.
    But then removed the injectors to replace the o-rings as one was missing and I realized I never connected the ground for the injector harness. There's the ground that was mentioned by the alternator, but there's another right on the fuel rail at the end of the injector plug harness. After reconnecting that ground, everything worked.
    Thanks again for the help!
    Good deal thanks for the update.
  1. No start after engine swap, GND wire voltage offset
    By jtb_116 in forum 3geez Accords
    Last Post: 06-21-2019, 06:12 PM
  2. No start, main relay harness ground voltage offset
    Last Post: 05-14-2019, 03:28 AM
  3. Accord fuel pump voltage
    By NickrWs6 in forum 1geez Accords
    Last Post: 03-19-2015, 06:38 AM
  4. battery voltage, pcv and starting
    By firefighterwhite89 in forum EFI Tech
    Last Post: 11-29-2011, 05:20 PM
  5. No voltage to fuel pump
    By DX87 in forum 3geez Accords
    Last Post: 10-17-2005, 09:46 AM
Tags for this Thread
