Results 1 to 17 of 17
Thread: manual Downshifting
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    manual Downshifting
    will manual downshiftin damnage my tranny?
    Nfld, Canada
    Re: manual Downshifting
    I wouldn;t say that it hurts the tranny (unless you're bouncing it off the rev limiter or something) but it certainly doesn;t help it. I don;t so it ALL the time or anything.
    WTB: 4th and 5th gen OEM headlights and corners in good shape. Even single lights.
    1995 Honda Accord EX-R | 1988 Honda Accord EX-i | 1987 Honda Accord LX (R.I.P.)
    Do you mean on a auto tranny?
    Like you are at d4 and you put at d3??
    If so its depends at what speed you are. If
    you are on the highway at 80mph and you switch to d3
    i dont thinks your tranny while like that.
    Anyways i always do that when i get out of the highway(40mph) and my tranny as over 300 000 miles.
    87accordlx's Avatar
    Sep 2001
    1987 honda accord lx
    Ontario
    i don't think so, just make sure your not at a high rpm when you do it, i downshift all the time in mine from4th to 3rd( mines a stick) at about 3000 rpm
    -Scott
    3geez member since Sept. 27, 2001
    "its a shame that our society as glorified the thug life. It just churns out fearless idiots with guns " - Pimp86LX
    Oct 2001
    87 Accord EX , 5spd , Manual
    downshiftin can be good and can fuck up your tranny if you shifted @ wrong rpms ! so it needs experience !
    MIKE
    Jdub07's Avatar
    1986 Honda Accord DX Hatchback
    Newark, CA
    If you drive an auto I wouldn't ever downshit...the car does this all on its own. If you drive stick (in my opinion) you aren't driving properly if you aren't downshiting. Reaction time is better, it's more fun and if done right I doubt it hurts much of anything.
    86 accord dx wrecked
    97 Dodge Neon
    Athens AL
    mines auto
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    But I feel bad for the guy that is behind you, that may leave quite a mess for them to clean up
    -Aaron-
    2.0Si User accordlx's Avatar
    1988 Honda Accord LX, 2006 Honda Ridgeline RTL, Pontiac Sunfire Convertible, & 1979 Corvette
    Cincinnati/Columbus Ohio
    Downshifting is bad for both kinds of transmissions. It's bad for automatics because automatics were not made to downshift in our cars and it causes extreme hydraulic pressures inside the tranny.
    Manual downshifting should not be done only if done properly. 90% of people do not downshift properly. Transmissions are made to speed cars up, not slow them down. (at least in our cars.) This is why we have brakes. Is it easier and cheaper to replace a set of brakes in your car or is it easier and cheaper to replace a transmission. You make the call.
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    I'd say it'll put a lot of un-needed wear on your engine and it's mounts(unless you match RPMs).
    When I'm coming to a stop in mine, I just leave it in the gear that it is in with my foot off the gas and then start pressing the brakes.
    Jdub07's Avatar
    Newark, CA
    My brake lights still work so the guy behind me I hope would be paying attention to that. I agree that using your transmission to slow to a complete stop is terrible for your tranny and could cause acidents. But to use it in conjunction with the brakes I see no problem in that. In my opinion useing only the brakes to stop, one would have to get new brakes quite frequently...and I agree with accordlx most people don't down shift correctly and a lot of people down shift through ALL gears which I feel is uneccessary. Everyones has different driving styles. I for one have the original tranny with 200,000+ miles on it and downshift about 85% of the time. I feel our hondas were the "Built Tough" cars!
    hatchback
    Mar 2002
    UT
    Hmmm...guess you guys aren't seing the humor here! Infact, it would leave more than a mess, it may require some disinfectant :p
    -Aaron-
    Jdub07's Avatar
    Newark, CA
    hey your right...poor fella
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I dunno I drop it in second gear @ 55 mph or so, and things are great... I have 2 B&M trans coolers and my little valve train mods
    Oh I added some B&M trick shift fluid to the tans oil but not that much, the bottle is still half full.
    I like downshifting next to nice cars... just to get a reaction.
    A20A1's Avatar
    Sep 2001
    Oh and I highly suggest downshifting to decelerate... at 120 mph or more if you try and use just brakes it takes too long or if you stop too quickly you could lose control, and wear out the brakes.
    1988 Honda Accord
    Ontario, Canada
    I have had my brakes done a couple times now and the mechanic at the dealership said to me....
    "Its better to downshift and let the motor/tranny do the braking than it is to just ride the brakes because the transmission is alot stronger and will last ALOT longer than your brakes ever will"
    so as long as you dont stick it in the red on a downshift, I'm sure you're okay..... engine braking is alot cheaper than replacing pads every couple miles.. then again, I'm pretty hard on my brakes............
    CoAsTeR
    88' Honda Accord LX
    www.coastersride.cjb.net
    Visit my website for pics and how-to's
    was an 89 coupe Lxi, but now is an 89 dodge colt hatch with a GST under the hood :)
    Valley Stream, NY
    i downshifted all the time....and thats why my first tranny went (the second tranny ever in that car...my friend who owned it blew it up the first time...)..since i learned how to drive altogether on a stick, i can say for myself that i downshift very well...i can sit back after quite a long time driving this car...and when i do downshift...can i always match revs to within 100-200 rpm of each other...sometimes right on the money....doing that....the tranny still takes abuse, but much less of it. The only tranny i used to not match revs on was my old Trooper..that clutch..from the factory was built tough, but then again...it never did past 60mph most of the time.
    When i beat on the tranny...that is, racing it on a twisy road and what not, i got a little carried away(mostly i think the straight pipe and the muffler contributed to it because up top it sounded all racey like) and downshifted like it was a freaking Touring Car, and did little or no rev matching at all, to slow the car down a bit for the turns. On my favorite stretch of road..the tranny gave out finally...from all that abuse...so dont ever downshift unless u know what ur doing.....just put it in neutral and use the brakes...
    There are 3 things that are most important in life....eating, sleeping, and racing.
  1. Trans not downshifting?
    By X-Lr8 in forum 3geez Accords
    Last Post: 10-11-2004, 08:48 AM
  2. Braking?, Downshifting?, RPMS? Please Help!
    By DenverLXI in forum 3geez Accords
    Last Post: 02-27-2004, 09:28 AM
  3. auto tranny downshifting
    Last Post: 06-29-2003, 10:19 PM
  4. auto tranny downshifting
    By ICEMAN707 in forum Classic Honda Pics & Videos
  5. downshifting
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 12-18-2002, 10:51 PM
