Results 1 to 3 of 3
Thread: Hub Spacers Anyone?
    Hub Spacers Anyone?
    I'm thinking about my wheel gap and what I can do to fix it.
    The obvious answer is to lower the car, but I'm not real excited about that. To me, it looks like the wheels are simply too small for the openings. I'd rather try to fit larger tires on the car and see what that does. I'd need to run some hub spacers to clear my UCA. I'm curious if anyone here has experience with hub spacers that they're willing to share.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Hub Spacers Anyone?
    Come on man, we live like wheel gap kings! Anyway, it all depends on how much you want to run. Spacers aren't quite as good as a higher offset wheel as very much will put you passed the hub center lip, you may need longer wheel studs, or you may need some with studs built in which can probably fix the other problems, but typically they'd be real wide and that adds stress to the ball joints and wheel bearings. This website has some pretty good tools to size your wheels and tires: https://tiresize.com/wheel-offset-calculator/
    After seeing your wheel gap, I've realized I have nothing to complain about. LOL.
  1. Question about strut spacers made from HDPE Polyethylene?
    By Burn1nRubb3r in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-02-2012, 05:40 PM
  2. where to put washers as spacers when doing 2nd gen lude arm swap
    By mykwikcoupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-19-2011, 04:30 PM
  3. pro and cons of spacers
    By b20a86lude in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-12-2009, 06:50 AM
  4. Wheel spacers
    By ivanfbi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-31-2004, 12:15 PM
  5. Wheel Spacers....???WTF???
    By markmdz89hatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-28-2002, 07:15 PM
