So, I know the service manual calls for a 10w-40, 20w40, or sae30 motor oil in the trans, but last time I filled it with Honda mtf, which should be about the same as a 30 weight. I don't know the cold performance of the Honda mtf, if its lighter like a 10w-30, or heavier like the sae30.
If you don't know, my trans started growling, after inspection of the clutch and trans out of the car I am not sure where the noise was coming from, but it may still be the trans. I did notice that my drain plug was finger tight, but it wasn't run dry to my knowledge and it never popped out of gear or anything that leads me to believe it was dry.
What would you put in the trans? I have a case of Honda mtf, but I might fill it with 10w-40 or 20w-40.
Idk what I will do if I have an input bearing going out... rebuild it I guess, but I cringe at the thought of sinking money in these unicorn trans. Noise was intermittent, moving or stopped, behaved more in high gear off/light throttle (I had to limp home 70mi), no noise with the clutch off. Sounds like clutch to me, as the input shaft wouldn't really make noise idling, with basically no load, I don't think, clutch started to feel like it was slipping too, but it looks brand new still lol. I should have it running by the first (my plates run out, so I have to lol), so we will see, fingers crossed.
