Results 1 to 11 of 11
Thread: FI Staying On
    FI Staying On
    OK I have a weird problem. My car is in the shop right now, but he showed me something very weird and I want to know if this has ever happened to you guys.
    My car has been running on 3 cyls and also my battery has drained the past 2 days overnight.
    It turns out that one of my fuel injectors is ON when the car is off. It's the fuel injector going to the cyl that is not working. This is quite strange. Any ideas on what happened here. I recently replaced my alternator, and am wondering if I messed anything up.
    Thanks.
    Just heard back from the mechanic. Seems I have a burned valve and possibly another problem. So far it's at least $600 of repairs.
    He's looking for electrical problems but is unfamiliar with the wiring. He says all the fuel injectors should be ground but one is constant power for some reason. It was not like this before. Anybody know why the heck this would happen?
    Figured it out. I smashed some wiring harness putting in the alternator. Put a new ECM (ECU? Difference???) in today now need to get the wiring harness fixed and I think it will be all set. Anything I should check for. PLEASE RESPOND SOMEBODY. Thanks.
    I guess I'll continue to talk to myself. I'm doing pretty good answering myself too. What a great board.
    Anyways the bastards at the wrecking yard LIED to me saying the EC* they gave me was compatible even though the last numbers on the part number was "684" and mine is "686" and they have a no return on electrical parts. Im now getting a driver from the 684 one and putting it in the 686 one which SHOULD fix the problem. Anyone see any potential problems with this? Anyone read this? Guess I'll take my chance..
    Hi Mom
    I'd like to give a shout out to all my boys at Midway. Keep it real. Hey I can do this because nobody is reading this post.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    heh heh no worries, ppl are reading, i guess they just figured you had everything under control cause you keep answering youself :lol :lol
    peace :pimp:
    10/Honda/Ridgeline
    NJ
    getting stuff from a store with no return policy (unless its a junk yard) is not a good place to even drive around. Those bastards are born to be asses.
    Yeah, I hesitated but this was my only car and I was strapped for cash so it was my only option. However, I've always believed that if you are going to run your own store then get enough balls to believe in what you sell, and that means offering a return policy.
    2005 Mazda 3
    Ontario Canada eh.
    u said it man
    Well I pick up the car tomorrow morning. They were able to switch parts between the 2 computers and make 1 good one and everything's good now. Thanks for the help.
    1987 Honda Accord LX 5spd
    Maine
    So what I want to know is what happened to the burned valve hypothesis? How did your mechanic determine that the head had a burned valve? Basically it sounds like it was a stab in the dark. He didn't even do a compression check did he? What a jackass. He should go back to work on his SBC.
    Glad to hear your car is working again though. Be careful with the wiring harness next time you're in there!
    Adam
    1986 3rd Gen LX 5spd 347K
    1987 3rd Gen LX 5spd 196K
    1. My mechanic is not a jackass and has not been for the past 12 years.
    2. He did a compression check.
    3. He showed me the burned valve, but was able to save it.
  1. Fan Staying On?
    By LX-i in forum 3geez Accords
    Last Post: 11-21-2009, 09:39 PM
  2. fuel not staying in bowl
    By mark_salad_bar in forum Carburetor Tech
    Last Post: 08-13-2008, 01:44 PM
  3. Car not reaching temperature or staying at temp!
    By 87AccordLXDude in forum 3geez Accords
    Last Post: 11-03-2006, 05:03 PM
  4. BRAKE LAMP LIGHT staying on......wtf!!
    By detroit313 in forum 3geez Accords
    Last Post: 09-17-2006, 05:44 PM
  5. pop up headlights staying popped up?!
    By 89blackdx in forum 3geez Accords
    Last Post: 08-21-2004, 05:03 PM
