Results 1 to 25 of 31
Thread: Trailing arm bushing options
    bscanlan's Avatar
    Jul 2012
    1988 Accord LXi Coupe
    Amherst, Ohio
    So I am approaching being done with replacing all bushings with urethane, and it occurs to me that I have not seen any such options for the trailing arm-to-body bushings which are so soft and sloppy. Has anyone found a compatible bushing to fit (like the one pictured, which of course is far too small)?Click image for larger version.
    1989 LXi Hatchback - Napster
    1989 LXi Sedan - sold 😒
    1988 LXi Coupe - Old Skool
    2023 Chevy Bolt EUV - DD
    Re: Trailing arm bushing options
    https://www.3geez.com/forum/suspensi...-bushings.html
    #23 correct? in the drawing.
    I havent heard anyone replacing it. Theres a civic style arm that alot of companies make a bushing/sperical bearing for might be an option.
    EDIT: this is the one im thinking maybe 6:35 min mark.
    Hard race video install hits about 6 min mark as well.
    nice to see you back on the forums. Let us know what you think.
    https://kingpinmachine.com/
    I have my eye on this guy for a while might be one to try out.
    I found an autoparts warehouse supplier that has these trailing arm bushings listed. I'm sure they are no name brand but anything is better than stock at this point. They had a minimum order of 4 so I ordered 8 (4 sets) I will sell you guys the remaining sets when i get them, shipping was expensive and says 24 to 42 days so, dont hold your breath. I'll let you know when i have them and when i can test to make sure they fit. I am confident they will fit as they looked correct online, are listed for the correct car, and are listed by the honda oem part number. They will be about $40 including shipping for a set.
    Thank you!
    Keep us posted!
    Has anyone tried the windshield adhesive trick yet? I'm considering it.
    Sorry to disappoint but they just now refunded my money to say these are not available. Mine definitely need replaced bad. I'm looking into the DIY poly bushings now. Don't know much about it but i assume i can take the old bushing out, clean out all the rubber and pour new poly stuff in there.
    On my other forum for Insights, many used the windshield adhesive trick for the engine mounts and it definately made them stiffer but they did work. I assume windshield adhesive would work pretty good on these mounts but i think you would need to take them off and make sure its straight before gunking it up.
    What is the OD of these bushings?
    https://www.hardrace.com/Product_detail.asp?id=2253
    https://www.hardrace.com/Product_detail.asp?id=2242
    Would it be worth calling an asking what the dimension of these are?
    Probably. They should be able to be turned down if theyre a few thou too large like the control arm bushings.
    I just want to point out that the solid bushings are $300 YEESH.
    I was really hoping an energy suspension bushing would fit. Don't remember what size the civic/integra bushings are now, I did when I last posted. I should really just grab some, theyre $35. https://www.suspension.com/16.7106
    Go big or go home?
    I sent a message to hardrace, but I also ordered the Energy Suspension 16.7106 for the Civic/Integra. I think its a bit bigger than ours so maybe it can be turned down on a lathe.
    I wish I could help more but I dont have any xtras of those suspension parts to play around with.
    I have a whole car to play around with, but the bad part is I have the rear end "jacked" up on its old wheels, its a little hard to get to. I will dig it out if I really need it lol.
    2 - 3317 - Trailing Arm Bushing -OD=75.42mm(2.96in) ID=29.10mm(1.141in) ,length=51.21mm(2in)
    Thats the specs of the civic bushing off your link
    I was looking all over for that, I knew I saw it was 3" somewhere. Yeah it should be able to be turned down, it will need a steel sleeve inside it.
    I saw a 3.16 or a 3.19 measurement some place and then the site was offline and I can remember where I saw it. It might have been youtube.
    I got them in, I didn't bother measuring them because they are absolutely massive lol. More than enough to turn down, now I am more worried about the width. It might be A LOT to turn down.
    ShiRen
    Any update on this. I can't wait a whole lot longer to replace all my bushings before getting tires for the winter on the car. If you think it can work, ill buy a set and have them turned. My brother in law has a lathe I could use.
    Thanks for your efforts so far.
    Im wondering if the front lower control arm bushing might be the way to go. I think that bushing is 1.100"
    I think the Civic ones will be fine, I started driving the car without aligning it, I just eyeballed the toe, never even took the trailing arms out. I did look at the width though and its actually pretty close, for having to turn it down it really should be a pretty good starting place.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    I have a spare OEM NOS honda bushing, was gonna take measurements to call energy or make a cast from it , but you might have gotten a better start on this. if you still need the measurements i can get them, just gotta find where i put it.
    3Geez resident body man
    Owner of Wreck-less auto body
    That would definitely be helpful
    That would be super!
    Here is a drawing of the dimensions. The civic bushings posted above aren't quite wide enough. The only issue i see with that is over time the bushing will slide out to one side of the sleeve.
  1. Rear Trailing Arm Bushings?
    By Robsan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-10-2015, 12:17 PM
  2. Trailing Arm Bushing
    By 88Sleeper in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-11-2015, 11:20 AM
  3. 85 accord rear trailing arm bushings
    By Taylor Smith in forum Wanted
    Last Post: 12-08-2012, 12:46 AM
  4. Rear trailing arm bushing diameter
    By Strugglebucket in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-04-2009, 12:47 PM
  5. Trailing arm differences
    By EricW in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-16-2007, 09:28 PM
