Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Trailing arm bushing options
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Trailing arm bushing options
    Where did you get the dimension for the width? I wash I had the bushings with me right now because I will 100% forget to measure them when I get home. The civic bushings gotta be real close to 1.5" in the middle. The ID is too large though so a custom sleeve will have to be made.
    conozo's Avatar
    Fort Wayne, Indiana
    I opted for using 3M Auto Glass Urethane Windshield Adhesive, 08693, 10.5 fl oz Cartridge to mostly fill in the bushing. The OEM bushing allows for a lot of twisting side to side but not much other directional movement. I filled in the gaps about 2/3 total on each side and put some extra around the top and bottom. It may not be the best but after looking at diy poly bushings they seemed way to stiff. This will buy some time to get it right next time. Also the small bushings on the other end of the trailing arm i filled in as much as i could since there are no replacement options for those at all/ever it seems like. They are the same style as all the other rear bushings but just half the length.
    Posting pictures before for reference and how I filled it.
    1988 Honda Accord LSDX-I
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Interesting solution. I did something similar with the rear engine mount in my ctr, but it was a poly insert instead, I guess the only difference here is the silicone or whatever it is is not a higher durometer than the og bushing. Thats one way to fix up an old bushing thats not totally blown I guess, I like it more on the training arm to knuckle bushings, no way there is a replacement for those. If I can get underneath my parts car to get a second set of arms I might opt for this on one set. Any reason you picked the windshield adhesive?
    conozo's Avatar
    Fort Wayne, Indiana
    My bushing wasn't completely shot but it was not as stiff as it would have been new. This solution is all over the internet for engine mount "fixes" so since this bushing looks so similar to an engine mount and doesn't have any true weight on it, im going to give this a try. I was moving it around today after it dried and i think im going to fill the rest in completely. It was still pretty loose, the urethane is pretty flexible, much more than i anticipated it would be.
    My end goal is to have a bushing that moves but is not sloppy. I didn't want the super stuff poly bushings that everyone does diy.
    Keep me posted on how this works, please. That's long been my fallback plan if I end up not being able to find bushings in the future.
    conozo's Avatar
    Fort Wayne, Indiana
    9 month/ 10,000 mile update.
    Bushings are still good. I did not end up filling it in completely, I installed them as pictured above. To note, before filling them in, spray them with some kind of cleaner, I used brake cleaner to clean off all the grease so the new adhesive would stick and it has. I give my approval for this mod for only this bushing.
    DX User Jacques's Avatar
    Jul 2015
    Bend, OR
    Here is a drawing of the dimensions. The civic bushings posted above aren't quite wide enough. The only issue i see with that is over time the bushing will slide out to one side of the sleeve.
    Does anybody have the exact dimensions of the trailing arm bushing? There is no drawing here.
  1. Rear Trailing Arm Bushings?
    By Robsan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-10-2015, 12:17 PM
  2. Trailing Arm Bushing
    By 88Sleeper in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-11-2015, 11:20 AM
  3. 85 accord rear trailing arm bushings
    By Taylor Smith in forum Wanted
    Last Post: 12-08-2012, 12:46 AM
  4. Rear trailing arm bushing diameter
    By Strugglebucket in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-04-2009, 12:47 PM
  5. Trailing arm differences
    By EricW in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-16-2007, 09:28 PM
