Finally found the leak on my 86 lxi hatch from a hose by my intake box and thought I should just end up replacing all my bypass hoses leading up to the thermostat housing section. Couldnt find any kits but I for sure want to replace them with silicone hoses. Also couldn't really find a solid answer on sizes. All the hoses lead up to a 4 way like splitter which I think is plastic but mine is super corroded. Only two hoses that look bigger is the one house going from the thermostat housing to the 4 way splitter. I think its thicker because its been replaced it doesn't have spring clips. Again not sure the variety of hoses you can use on the hoses, as well as temperature but I think silicone should do the trick. So basically just need some recommendations or what you guys have done for replacing radiator hoses. Thanks!
