Results 1 to 2 of 2
Thread: gas tank leak?
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    gas tank leak?
    ok..i crawled under the car after shoveling it out to see what the gas smell is all about...what i saw wasnt too bad...there was some gas leaking out of the top of the tank it looked like and then coming down a tube which i think lead to where the filler is. Im hoping its jut a loose clamp on top of the tank..because it was parked on a hill and its not like its pissing out gas..just a real slow leak. Im just wondering if anyone has any ideas on what this could be or if i may be right..and im hoping this gers more of a response then my last post...
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    its prolly a hole.. my tank has a hole and i can get a pipe welded on till i fix it.. i am just getting a new one put in with a new hose right to the carb... 240 canadian
    Travis
  1. leak in radiator reserve tank
    By BrokenBone in forum 3geez Accords
    Last Post: 09-04-2011, 03:52 PM
  2. Oil leak Found.. now an even worse oil leak....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 03-11-2011, 08:46 PM
  3. Gas Tank
    By ImportMidnight86 in forum 3geez Accords
    Last Post: 09-11-2003, 01:27 PM
  4. 88 gas tank to an 86?
    By racinevrywhere in forum 3geez Accords
    Last Post: 03-26-2003, 01:22 PM
  5. gas tank ?'s
    By Experimental_Honda in forum General Engine Swaps
    Last Post: 01-29-2003, 07:31 PM
