Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 109
Thread: Sudden drop in power then lurch
  1. #76
    LX User Sandwich's Avatar
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Re: Sudden drop in power then lurch
    So I checked the fuel system and ran the 'Fuel Pump Inspection' test (pg 12-50), bob's your uncle, it seems.
    https://photos.app.goo.gl/mniVzWVV1hD9h5N3A
    Nothing came out of fuel pressure reg, looking for at least 230ml petrol, nothing came so according to manual its gonna be:
    fuel pump
    fuel filter
    fuel line
    pressure reg
    In order to run the test I relieved fuel pressure at the filter, petrol did flow out, makes me think its fuel filter or regulator then, or a downstream pipe. Filter seems top of list given its a maintenance item.
    Any further thoughts?
  2. #77
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    If you're sure there's actual petrol in the tank, filter and regulator are first to replace now. Then try again. Hopefully on your way to have it start at least. Let us know. Carb cleaner test could easily confirm if it will start when fueled. So would try this test first
    Verstuurd vanaf mijn E5823 met Tapatalk
  3. #78
    im starting to suspect your tank is rusty or possible fuel line corrosion. you have pretty low miles meaning the car sat alot unused.
    The pumps under a small round hatch back on car as well as the fuel sender under a separate hatch. There pretty easy to pull and peak in there. The metal edges are very very sharp just a warning.
  4. #79
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Yeh, Im suspecting the same I think, car on 130k granted but sat for the last 13 years in storage before I bought it...
    Cheers for the warning, gonna try the gauge-side hole and see if I can fix the hanger while I'm at it, will be back with photos. Maybe I shoulda bought two filters
  5. #80
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    I'm not sure about parts availability over the pond, but over here tanks are pretty darn cheap still, so if you look down in it and its real bad I would not be afraid to write it off and order a new tank. It is very likely this is a big part of your issues, if not the root cause.
  6. #81
    Nov 2017
    I’m having a similar issue with my 94 Civic. If the idles are unstable and the car gets jerky under load, i think it might be your IACV. Try disconnecting it and go for a drive and see if it still jerks.
    You’ll get a CEL, but that shouldnt be a problem as long as you don’t leave it that way for too long.
  7. #82
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Quote Originally Posted by gcovarrubias412 View Post
    I'm sorry, but PGMFI went a long way between 89 to 94. The two are hardly related.
    A stuck IACV is an extremely common problem on later cars, you should just clean it as preventative maintenance if you take one in.
    I think his problem goes a lot deeper than an idle control valve, that is what we are looking into.
  8. #83
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    So I got the fuel gauge sender out, looks quite manky, cleaned a decent bit of dirt/rust off it. The connection was gone so need a new one too.
    I'm a bit of a tit, doesnt look like much fuel in there either, likely explains why it won't start I reckon, gonna fill and find out if its still playing up. In my defence the gauge was off
    How does the tank look to your professional eyes? seems some black gunk on the sides, and general rusty vibe, no clue how bad that is for a petrol tank. Vid: https://photos.app.goo.gl/vdg9tQfuxs3QHjGS6
  9. #84
    Quote Originally Posted by Sandwich View Post
    Well mate.....YOUR OUTTA GAZZZ. or petrol in your case.
    And yes thats very rusty. It really wont every run well consistently without a new clean gas tank and probably new fuel pump set up. As you can see from mine it should be all shiney galvanized metal.
    EDIT: https://www.3geez.com/forum/3geez-ac...ml#post1221892
    I left two vids on this post.
  10. #85
    Feb 2017
    the Netherlands
    Wouldn't that be nice if that solves the no start . Try petrol in first, replace fuelfilter, and see what happens. Go from there, google diy tank cleaning, or get another one.
    Curious now what happens .
    Verstuurd vanaf mijn H8314 met Tapatalk
  11. #86
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    I have cleaned smaller gas tanks out by putting gravel in them and shaking them around. I won't say it is long term, but it works. Don't try to put a tank liner in it unless you like not having fun, or you like breathing harmful chemicals.
    If you were American I would tell you to fill it with gravel, wrap it in an old rug, tie it behind an atv and take it yard skiing.
    I would just put a gas tank on your shopping list lol, but a dirty tank won't stop you from getting it running, at least for some time. Maybe grab a second fuel filter for later.
  12. #87
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Yeh gonna do some shopping for tank repairing/coating stuff or ultimately a new one, might be my christmas present this year
    Gravel dragging sounds great fun, not sure if I could get away with that over here though hahah.
    The gauge sender units are out of stock on RockAuto, anyone seen them elsewhere? Would be nice to know my fuel level I realise.
    Got some petrol will update when I give it the next start.
  13. #88
    If you change the fuel filter that would help too. All those little rust bits are clogging everything.
    Sender doesnt seem to be available right now.
  14. #89
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Gave it a few runs round the block at lunchtime, starts and idles well, pulls nicely, nice to see how these engines are meant to be!
    Problem persists however, as it warmed up. Also I get a 'screech' just after changing gear. Both can be seen in these vids: https://photos.app.goo.gl/N75CKJGnrPyWqBSx8
    Cant tell if the screech is tyre spin from a heavy foot (can't feel much in steering wheel), or something else, open to any suggestions.
    Fuel filter on way, hopefully will fit that and it will alleviate problems.
    Thanks for all your help guys!
  15. #90
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    I am not able to watch the video at work, but I would suspect you are hearing the belts slip. I have to get mine pretty darn tight before they stop making noise.
  16. #91
    Well its my birthday and I got coffee in bed and your car running. Pretty good day.
    I think it runs great for running it dry and rust in the tank! I seen them two girls checking you out at the stop sign.!
    Id leave the timing where its at I didnt hear it pinging. Double check your timing belt tension sometime and let it roll.
    Belt squeek is probably from a low battery needing a heavy charge and I think your clutch seems to hang a little between shifts which is typical on a car that sits.
    Good day otherwise.
  17. #92
    Nov 2017
    I just saw the videos he posted. Seems like his issue is exactly the same as mine. Although i dont think my car smokes like his.
    I’m almost sure its the IACV. I disconnected mine and the problem went away. I’m hoping to replace it soon and see the difference so I can report back here to see if it fixed it.
  18. #93
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Good day otherwise.
    Happy Birthday Blue! fingers crossed this fuel filter sorts it out and both of us can rest easy
    I'll see what messing with the IACV does in the meantime, filter not gonna come until Friday/Saturday and anxious not to waste any time, I wanna drive this thing a couple hours home home this weekend, taking the train would be admitting failure
  19. #94
    Thanks for the Birthday wishes.
    I would wear a really good pair of shoes on that trip.....
  20. #95
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    So I was fiddling and noticed this on the floor, when I hadnt noticed it previously, it hasn't pinged off anywhere has it? looks more like a house electrical thingy but wanna be sure I havent knocked it off. Cheers.
  21. #96
    Feb 2017
    the Netherlands
    450 Volts . Not car related.
  22. #97
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Those are nice little clips, essentially a wire nut... still not something you permanently splice wires with.
    Its not factory, bit you now may have a bare wire under your dash somewhere
  23. #98
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Yeh will have a good look see if anythings bare, was when I was trying fiddle with the ICM. Live in flats though so could be anyones crap equally haha.
  24. #99
    Oct 2020
    89 Aerodeck EXI
    UK - Bristol
    Replaced the fuel filter, can't work it out...
    My current feeling is it's improved but not fixed. The car drives well, pulls nicely, yet I still get the cutting of power, now centered around the low revs. I gave it a few runs round the block and it suffers most when pulling off, just nothing happens. The revs dip and dance around low before eventually recovering. It caused the car to stall a couple of times. In the last video you can see it idle nicely, suffer at the beginning but then hold revs really nicely. The vids are a few mins but show how it occurs at low revs really well.
    https://photos.app.goo.gl/1WWYcu5jYgCmy8Gb6
    Still need to set dizzy timing, and tension alternator belt, but doubt these will fix it. Not sure...
    My thoughts, maybe check the fuel pump sock? with the state of the petrol tank maybe thats partially 'blocked' too. or somewhere else in the fuel system,
    Something electric? a sensor, IACV? or similar, something causing the engine not to hold revs well at low revs.
    Time? gonna drive it some more, see if it sorts itself out, who knows, it was idling and holding revs nicely when I got home.
    Fucked? is the engine itself just fucked
    Cheers.
  25. #100
    Im more thinking it needs a good "Italian tune up" my dear Sicilian Grandma wold say....floor board it up a big hill.
    Thats the problem with rust it comes and goes and does all kinda things one not the same as the other. There is no solution that dissolves it so its probably stuck in you injectors.
  1. Sudden engine trouble
    By Maliciousmisery in forum EFI Tech
    Last Post: 12-02-2010, 08:12 PM
  2. Power Steering Pump making groan, drop in rpm
    By 1988 in forum 3geez Accords
    Last Post: 04-12-2009, 08:49 PM
  3. sudden clutch failure...
    By paul in forum 3geez Accords
    Last Post: 08-14-2008, 03:42 PM
  4. Sudden big problem
    By Bfarrell01 in forum Carburetor Tech
    Last Post: 01-21-2008, 07:31 PM
  5. Accord Power drop problem?
    By Hecubus84 in forum Interior & Exterior Care
    Last Post: 02-12-2006, 11:15 PM
