Results 1 to 3 of 3
Thread: helpppp
    Jan 2019
    Post helpppp
    i need help taking apart 1985 accord tailightsssss
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: helpppp
    You should make your posts a little more in depth so we know what you're getting into and what you have tried.
    Be careful if these are the only set you've got, but they are probably glued together. I have only done headlights before, but you can put them in the oven at 250F for 10-15min, you need to remove everything flamable/meltable first. The plastic itself should be able to withstand quite a bit of heat, but keep in mind it is not a pizza.
    LX User Jinnai's Avatar
    Jul 2020
    Colorado Springs
    Re: helpppp
    I don't know about the 85, but the 86 is there a way to fix the spiderweb cracks they form in the plastic?
  1. Fuck meeee helpppp
    By mitsumi in forum 3geez Accords
    Last Post: 10-07-2006, 06:30 AM
