Results 1 to 9 of 9
Thread: Tallest Tyre You Can Run?
    Oct 2020
    1987 Honda Accord
    Victoria
    I've just grabbed myself a 1987 Accord with a Mugen Bodykit installed. The tyres on it are 195/60 R14's and are due a replacement.
    I live in a rural area with pretty bad roads so, protecting the bodykit in mind, I was wondering if I'd be able to add some height to the car with some new tyres.
    What are the tallest tyres you could comfortably fit on these cars?
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Tallest Tyre You Can Run?
    195/60r14 is already extremely tall at stock ride height... How tall are you wanting to go?
    There is a section of the wheels and tires thread that gives you a pretty straight answer, but keep in mind wheel offset is going to affect rubbing
    https://www.3geez.com/forum/suspensi...els-tires.html
    Quote Originally Posted by AZmike View Post
    OEM Wheels
    Stock 14”x5.5” 45 mm offset 4 x 100 mm bolt pattern
    88-89 OEM 14" alloy wheels weigh 17.1 lbs (thanks CAH)
    Stock 13”x5.5” 4 x 100 mm bolt pattern
    Civic and Integra wheels fit
    13" wheels do not fit on 88-89 fuel injected cars because of the larger front brakes
    Maximum size
    215 width fits with 45 mm offset wheels
    225 width fits with 40 mm offset wheels
    195/70R14fits at stock height (outer diameter 24.75” 106.6% stock)
    195/60/14 is the stock call out on the Lxi models. Not really sure how high you can go or whats available in 14" in your country.
    Oct 2020
    1987 Honda Accord
    Victoria
    Thanks for the replies guys,
    I think I'll try measuring out whether or not 195/70 R14 is going to scrub or not. If it fits it should hopefully help my bodykit stop scraping on every gravel road.
    Wwe.tirerack.com. is a good one to just put in your size and play around with the numbers.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Tire rack wont really tell you what size fits
    https://tiresize.com/comparison/ and https://tiresize.com/wheel-offset-calculator/ keep the offset the same, it will show you how much bigger the tire is depth wise. Not every size exists so you might have to check tire rack for that. Like if there isnt a 195/80 there might be a 205/70
    Roll it on dubs yo!
    Quote Originally Posted by Feature View Post
    195/70/14 is listed as 24.7" tall 5.6" wide, widths vary by tire maker
    195/60/14 is listed as 23.2" tall 6.5" wide, widths vary by tire maker
    https://www.tirerack.com/tires/tires...enis+RT615K%2B
    I have run 205/50/15 and there listed same height just wider and I know they work,but that is a 15 inch rim.
    I know alot of guys run the 17 inch rims and the shortest tire I can find is 24.3"
    I just got some Cooper cobras tires and they list (3) 14" sizes. but there all 25 inches or taller.
    https://www.tirerack.com/tires/tires...TRWL&tab=Sizes
    So that will give you some numbers to mess around with. Finding what you want might be hard in the 14" rim size since those tires are just not popular anymore.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    The 195/70s are already a massive increase, a lot more than I would want to go. If you need more height add some strut tower spacers lol.
    Off topic, but since you are in Australia, you should seriously look into investing in a good radiator. I am running a Skunk2 349-05-1000, some modification involved, but fits for the most part.
  1. Tyre Question
    By ab20000 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-06-2010, 08:53 AM
  2. Replies: 5
    Last Post: 12-29-2009, 10:05 AM
  3. Tyre size
    By John Sweeney in forum 2geez Accords
    Last Post: 11-15-2008, 03:01 PM
  4. Stock Tyre Size
    By bucket_man in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-18-2005, 03:36 PM
  5. Whats the best rim/tyre size with stock suspension?
    By ChthonicPowers in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-11-2002, 01:05 PM
