After months of trying to arrange a replacement V5 to enable me to register the car in Ireland, I'm delighted to say I've finally got the car and started assessing what needs to be done to restore it. The list to start with - car has been off the road for around 4-5 years:
1) Rad cooling fan melted, due to motor seizing and overheating (managed to get a fan from a Prelude an make one good assy)
2) Checked T/Belt and it was in very good condition - Engine fires first time and sounds sweet, so a full service, synthetic oil, valve clearance adjustment and ignition timing check, it should run even nicer
3) Most of the electrics work with exception of the sunroof, electric antenna (clicking but not extending).
4) Hand brake cable seized, so not holding the car (could probably do with a couple of front brake discs - slight pulsing in the pedal)
The worst items:
5) Both rear wheel arches require replacing (have replacements sourced through Cadeon)
6) FWD Inner sections of the rear wheel arches are quite bad, and will need to be repaired with filler sections [any tips on this would be greatly appreciated]
7) Both rear sections of the door sills will most likely need repair [advice on where to source sill repair sections also welcomed]
8) Passenger and Driver floor wells were filling with rain water and carpet was starting to smell, but I think this was due to a combination of a poorly sealed replacement windscreen (LH side), and sunroof drain separation at the footwell on the RH side (testing ongoing!)
The car is so rare here in Ireland, the Vehicle Registration Office didn't even have a code in their system for it
...so I'm really looking forward to getting her back on the road!!
