Results 1 to 11 of 11
Thread: 1988 Accord Coupe Import Edition
    Been a long time since I've posted on here, but here I am with another project thread.
    This car was actually spotted on here about 13 years ago (https://www.3geez.com/forum/classic-...-coupe-nz.html) and just over a year ago I saw it pop up in an auction. Of course I wasn't going to turn down the chance to own possibly the only 3g coupe in NZ, so I won the auction, flew down to the car and drove it back home. it drove really nice, though the power steering was a bit notchy and it did lack power, but then again it's over 30 years old so I'd say I'm lucky those where the only issues I had.
    No plans of going crazy with this car, I only want to do OEM-ish stuff to the car. basically a 2.0si conversion (like how it should've come from factory) and maybe some era correct stuff. anyway onto the pics
    weird as hell getting used to driving a LHD, even after a ~1600km drive
    never seen an inside this clean before
    Re: 1988 Accord Coupe Import Edition
    and then literally the day after I get back from its long trip this happens
    burst heater hose, which soaked the dizzy and got the igniter? wet and made the car die.
    so off i go to the parts car to get some bits
    since i've already had the car for over a year, and I can't leave things alone, plus with the help of my hoard of cars & parts over the years, i can do most tings i want to it for free. first on the list is swapping in some digital climate controls.
    first i'll need one donor car
    then some wires
    make it all work
    and make it plug n play
    and done
    next up is a rear disc brake swap
    even gave them a clean
    now one of the main parts of a 2.0si conversion. a B20A! I have a manual gearbox for it, but I'm leaving it auto cause it actually works good and I really don't mind it. plus I don't have any LHD manual pedals.
    and of course the mandatory clean of the engine & bay
    even cleaning the spark plug leads makes a difference
    degreased and waterblasted
    in its hole
    had to take the black box off the a20 for it because of the RHD & LHD differences. the A20 also has 2 extra solenoids in there which the B20A doesn't use (vacuum advance & evap), so those wires where repurposed for the solenoids on the auto gearbox (cause the A20 didn't have any) also had to run a pair of shielded wires for the crank? position sensor since the A20 didn't have one. i used the secondary o2 sensor wire for the B20As igniter since that also uses a shielded wire, but only 1 o2 sensor
    speed sensor box thing also has to be swapped for the TCU to work properly (someone in the past has removed its "you're going too fast" beeper). I should've piggy backed that onto the other one because now the seat belt control box doesn't know when the speed is over 10mph. oh well
    6500rpm redline tach swapped also, because 2.0si
    installing TCU, also made to be plug n play
    mugen shocks also installed. not sure how much of a difference these make
    a20a vs b20a exhaust
    and the b20a swap is about 95% done. runs and drives so that's the main thing
    also comparing a US spec bumper to a JDM spec bumper, while installing a little oem lip
    some folding mirrors. matches enough till the car can be resprayed
    someone already hacked a sedan folding mirror on this side which will probably explain why its alignment was shit and I couldn't see out of it properly. oh well, they work. I need a coupe mirror base
    some fog lights
    a quick restore before the rust owns them
    installed
    and i gave it its first wash since i've had it
    the paint is really bad which is why i never bothered before. I'd like to respray it some day.
    now all the progress on this car is up to date
    Super nice write up. Thank you.
    Lotsa work done there. Very nice. You have a LHD coupe, with leather, an A20 and some red interior color I've never seen. Far out man.
    Nov 2020
    1989 Accord Lxi coupe
    you literally have a car i'm trying to get all the import badges from nice tread by
    the way
  1. Honda Accord coupe 2.0 American Import Edition
    By Desi Vasileva in forum 3geez News & Site Feedback
    Last Post: 11-21-2018, 05:46 AM
  2. My Accord Coupe Import Edition
    By tipo2009 in forum Classic Honda Pics & Videos
    Last Post: 11-19-2018, 05:50 AM
  3. CAH: 1988 Accord LXI Coupe buildthread
    Last Post: 09-01-2014, 01:58 PM
  4. Replies: 0
    Last Post: 10-16-2012, 06:25 PM
  5. 1988 accord coupe
    By wprocomp in forum For Sale
    Last Post: 03-26-2010, 09:19 PM
