Results 1 to 5 of 5
Thread: Mounting front License Plate?
    Jan 2021
    1988 Honda Accord LXI
    Chicagoland
    Hi all,
    So I finally pulled the trigger after looking for almost a year and I bought a 1987 LXI Hatchback from a non-rust state. Zero rust, which is rare if not impossible to find in the Chicago area where I live. This brings me to my question. It never had a license plate mounted on the front bumper (therefore this isn't even a bracket) but I have to here in Illinois.
    Original '87 brackets have proven impossible to find, so I have to do something on my own. What is the best way to mount? Has anyone ever had to do this? I see the bumper has 2 bumps in the front center for a plate but I can't tell if that is just for the OEM bracket to situate in, or do I drill it? I think the OEM mount attaches underneath but I'm not sure. Any advice on how to mount? I don't want to drill until I absolutely have to...
    Re: Mounting front License Plate?
    This is the hardware off my 89.
    The large piece mounts to the bumper in this location. The threads are just loose steel tabs. They sit inside the plastic cover and don't mount to anything. If you remove the bolts, they flop around loose inside the cover. Threading the bolts back in is a bit tricky because you have to orient the inserts correctly before it will work.
    The support rods mount below in this location.
    Hope that helps.
    I hang mine off just the brackets connected to the crash guard, saves the bumper and I think it looks better lower... it does make me laugh to see it giggling around though.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    I have an NOS OEM front plate bracket for an 88/89 front bumper... no idea if it's the same as an 87 bracket though...
    Jul 2020
    Honda Accord Aerodeck
    I use the bracket for a 2007/11 Honda CRV. I bolts right in and looks OEM.
  1. DIY license plate smd led strip
    By 1stgen!!! in forum 1geez Accords
    Last Post: 07-07-2013, 01:02 PM
  2. Number plate/ registration plate mounting
    By Australian 86 in forum Interior & Exterior Care
    Last Post: 06-05-2011, 05:13 AM
  3. No front license plate?
    By w261w261 in forum Interior & Exterior Care
    Last Post: 06-17-2008, 03:07 PM
  4. front license plate
    By djcslice in forum Classic Honda Community Chat
    Last Post: 03-16-2006, 04:04 AM
  5. License plate ideas
    By 89dxowner in forum Classic Honda Community Chat
    Last Post: 05-21-2004, 01:40 PM
