Results 1 to 5 of 5
Thread: rebuilt started, but not great! 88 Accord manual
    May 2006
    03 exl adn 88 lx have had 89 & 91 ex and
    San Antonio
    So, finally got everything put back together and it started right away. Good news. The rest, well....
    1. I have a cylinder not firing. Leaving that till I get the rest fixed. I pull wire from distributor and no change on 2. Plug out shows spark. I replaced plugs last time in 04 and about 50K miles ago.
    2. Started and after warm, idle stays at 2200 or higher. No adjustments make a difference. Guessing Vacuum.
    3. Braided fuel line is leaking where it attaches to carb.
    4 Braided line from canister to back of carb seems to already have been repaired. Why in the world does that need to be braided?
    Questions.
    1. The check valve just before throttle diaphragm broke. I am using generic, it doesn't show in my shop manual, is it needed?
    2. From above, the braided line from coal canister to carb is probably part original, Can I go to a more pliable part of cable and splice it. Does it have to be braided?
    3. What other vacuum mistakes could I have made? I took pictures, Everything not connected to air cleaner is back!
    4. Before I got rebuilt carb, I did a pretty extensive vacuum test...
    Thanks
    May 2006
    San Antonio
    Re: rebuilt started, but not great! 88 Accord manual
    it seems the issue is with the choke. The only way to get idle down is to force it against the vacuum pull, I bull the hose closest to choke and engine races even more!
    Couple things I would look for real quick:
    Engine off! make sure the throttle blades are not hitting anything all the way open and closed. Sometimes you need to loosen the carb and wiggle it around to get everything set and free.
    Vacuum leaks!
    Id compression check the #2 cylinder...no compression is not gonna work well with a 4 cyl carb.
    Those lines that are red I never new really what Honda was up to with them. I would say there rated more for PVC fumes(emissions) then standard lines.
    May 2006
    San Antonio
    It was thermovalve a not hooked up properly! Thanks
    Very cool easy fixes I like!
  1. Rebuilt Manual transmission - how it works.
    By slithica in forum 3geez Accords
    Last Post: 05-27-2018, 11:40 AM
  2. Replies: 27
    Last Post: 07-27-2014, 09:58 AM
  3. Rebuilt carb swapped, runs great except at idle
    By Burn1nRubb3r in forum 3geez Accords
    Last Post: 01-01-2012, 09:56 PM
  4. I got the Accord started today...
    By TJ89Accord in forum Classic Honda Community Chat
    Last Post: 12-20-2003, 06:56 PM
  5. Great news: Shop Manual additionals
    By Paul Aerodeck86 in forum 3geez Accords
    Last Post: 10-27-2002, 11:51 PM
Tags for this Thread
