Results 1 to 8 of 8
Thread: Suggestions , Performance Mods / Bolt Ons
    Oct 2001
    87 Accord EX , 5spd , Manual
    Exclamation Suggestions , Performance Mods / Bolt Ons
    UPDATED FAQ FINISHED LIST
    EXHAUST
    Choose right performance muffler, exhaust pipe diameter, and high flow catalytic convertor.
    HEADER
    List of available headers for the A20
    WEBER
    What Weber Carbs are available for the A20? How to install weber
    WEBER TUNING
    How to tune your WEBER
    IGNITION
    CAMSHAFT
    FORCED-INDUCTION
    Quote Originally Posted by Mike
    " what can i do to make my car faster ?? "
    a question repeats itself on the board !
    so i am asking the guys who know much about performance stuff and their prices to write a small FAQ about what can be done to a car with approx. prices so new people can decide the best thing for the buck !
    thank you very much guys !
    BTW there is a FAQ on turbo already so i am gonna merge it with this one once it's finished !
    https://www.3geez.com/forum/showthrea...ighlight=turbo
    some of the prices and brands are available here !
    https://www.3geez.com/forum/showthrea...s=&threadid=94
    MIKE
    1988starter
    Guest
    Ignition
    For peformance gains this is a later item you may not notice much more power but the engine will be smoother and should run better.
    Before some major mods all I would suggest is an accel super coil (look in the faq for part number and install)
    as for plugs NGK are the best and their wires are also good
    I am partial to magnecor (sp) and crane cam fire wires.
    Msd 6 series 100-250 on ebay is the best place higher prices may include coil
    http://www.msdignition.com/
    wires
    NGK (20-30$) www.nopi.copm
    Magnecor (50-90$)
    crane cam (universal) (30-40$) www.martelbros.com
    www.cranecams.com
    Nology hot wire (120-150$) www.nopi.com
    Plugs
    NGK R plugs (1.25-2.5$ per plug) Autozone or any where on line
    NGK Irridium Ix Plugs (about 10$ per plug) Ebay
    Coils
    msd blaster (30-50) ebay http://www.msdignition.com/
    accel cloil (15-50) ebay autozone online dealers www.mrgasket.com
    combine it all together
    www.martelbros.com www.summitracing.com
    Intake system
    Short ram EFI only (LXi EXi SEi) 92-95 civic intake (20-200$)
    cut about 3-5 inches off filter end
    www.ebay.com www.nopi.com
    cold air
    2.5 inch is the best diameter no widning of the hole
    90-93 accord intake 4 cyl hole to fender may need to be widned
    hi po Filters
    www.knfilter.com
    www.martelbros.com
    Cams reground (provide own core)
    Colt cams canada between (120-200$) 25 return shipping
    Standard and tri flow both wild and mild. Both EFI and Carb
    Power Triflow 10% depending on mods I think 7 % for regular
    ask YK86
    Bullfrog cams ?
    Open loop motor sports 150-200$ I think 20 buck return
    7 horse and up I think both EFI and Carb
    ask justanothermike
    well here is some research done by bobafett !
    Originally posted by bobafett
    ok i dunno if you guys care, but here is what i spent the last 20min gathering info for... i was trying to get prices for 2.25 for amber, and 2.5 for me... the results are in. SS is NOT worth the price! at least from jcwhitney!
    without further ado:
    2.25" Aluminized Exhaust
    4) 45 degree bends. $6.69 = $26.76 81ZX2929P
    2) 90 degree bends. $7.69 = $15.38 81ZX2952B
    1) Straight pipe. $15.99 = $15.99 21ZX3253X
    Total = $58.13 + S/H
    2.5" Aluminized Exhaust
    4) 45 degree bends. $8.29 = $33.16 81ZX2930Y
    2) 90 degree bends. $9.79 = $19.58 81ZX2953P
    1) Straight pipe. $16.99 = $16.99 21ZX3254N
    Total = $69.73 + S/H
    2.25" Stainless Exhaust
    4) 45 degree bends. $27.95 = $111.80 47ZX6162X
    2) 90 degree bends. $31.95 = $63.90 47ZX6174B
    1) Straight pipe. $76.96 = $76.95 94ZX9080P
    Total = $252.65
    2.5" Stainless Exhaust
    4) 45 degree bends. $27.95 = $111.80 47ZX6157X
    2) 90 degree bends. $52.95 = $105.90 47ZX6181X
    1) Straight pipe. $87.95 = $87.95 94ZX9081Y
    Total = $305.65
    Jan 2003
    1994 Honda Accord EX
    Ottawa, IL
    Just a suggestion, when writing this make sure it is clear. Too many damn people do not know how to write effectively.
    You need to do it in steps, start with the easier mods.
    Do something like:
    For the beginner, a quick and cost-effective way of adding a good dose of horsepower is to change the stock air-intake system. When working on this, you need to remember the engine is also like a large air machine. The more air it can push in; and, in return push out, the better the engine will run.
    For changing the air system, you would need a short-ram or a complete Cold Air Intake (CAI).
    There are advantages to doing both systems, each has their pluses and minuses. Here is a quick break down of each:
    Short Ram:
    Description: The short ram is a short length of tube that comes directly off of the throttle body and has a cone filter attached to the end of it. It is (in our case) heading to the passenger side of the vehicle.
    Plus: Easy installation, overall cheaper in most cases.
    Minus: Less Horsepower than a full CAI
    Minus: Possibly could damage brake lines if installed incorrectly
    Cold Air Intake:
    Description: A full tube that runs from the throttle body to the passenger side front wheel well. This draws cold air from the bottom of the vehicle, in return causing more horspower.
    Plus: Maximum amount of horsepower for the intake.
    Minus: Harder to make and install.
    Minus: Possibly can ingest water and clog motor.
    Installation and Fabrication of Short Ram
    A good way to make the short ram intake is by buying a 92-95 Civic intake. These are already fabricated for the vehicle, and mostly come with a filter. These can be found on eBay from anywhere between $20 to $200. You DO have to remove about 3-5" from the intake tube, but can be measured by placing it in your motor off of the throttle body and measuring it out. Take into account where it will go by the brake lines, you may have to place a protective covering over the lines or make a bracket so the intake does not touch.
    Another possibility that can be done is installing a filter directly onto the throttle body. This can be done by purchasing a filter with a rubber coupler on it already and clamping it onto the throttlebody.
    Link to 92-95 Intakes on eBay: http://search.ebay.com/search/search...5+Civic+Intake
    Installation and Fabrication of Cold Air Intake
    These are by far harder to make than a short ram intake, but definantly DO pay off.
    A How-To on the subject has already been made:
    https://www.3geez.com/forum/showthrea...=&threadid=166
    If you would like more information on the differences in horsepower between a CAI and a Short-Ram intake, check out a post Jim made. With a true CAI you can get nearly 20 horsepower.
    https://www.3geez.com/forum/showthrea...&threadid=8201
    Do something like that
    Jul 2004
    Quote Originally Posted by ACCORD EX
    are these cams for EFI and carb ! how much approx HP gain !
    what about intake can i say 1>3 HP gain ?
    MIKE
    hey, about the intake horsepower gain, i think it would me more significant than that, there was a thread somewhere on here that listed power gains on a civic b18c1 swap or something, and it pretty much came down to a 1.25:1 temperature to horsepower ratio, so basically i think when the lowered the temp 25 degrees they gained 20 horsepower, i would think it would be around the same for most somewhat modified cars, atleast with an exhaust or something
    if junkyards didn't exist, neither would my car...
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    hahahahahaha, no
    more like 1 hp per 10deg
    I havent forgotten my roots
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: COMPLETED FAQ'S & FAQ SUGGESTIONS , PERFORMANCE RELATED
    Quote Originally Posted by FyreDaug
    Typical intakes are 2-4hp, you might think its more because it sounds different, but no.
    this also depends on supporting mods. if you have other mods first, like exhaust, header and or cam, you will gain substantially more than if you upgrade your intake first.
    some cars gain up to 30whp just from an air intake (usually turbo cars).
    im not disagreeing with you, because u are probably right, im just pointing out that there are higher potential gains if you have supporting mods, and you would likely see more than 2-4hp
    Mar 2006
    Holland, MI
    does anyone know the hp gains from upgrading to Weber carbs?
    Banned CipJug's Avatar
    Jul 2009
    Suggestions Performance Mods / Bolt Ons
    If youre gonna add stuff that throws a code, you might as well spend the money for a good software tune to keep the codes out and tune the car for the performance mods youre having installed.
  1. Performance Suggestions, Please Help
    By 1988HondaLXIAccord in forum Performance
    Last Post: 01-27-2009, 07:34 PM
  2. Cheap Performance Mods?
    By Zt527 in forum Performance
    Last Post: 12-20-2007, 09:12 PM
  3. performance tire suggestions???
    By 88'er in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-18-2004, 11:27 AM
  4. performance mods
    By Low Tek in forum Performance
    Last Post: 12-03-2002, 12:25 AM
  5. Performance mods???
    By 87blueaccorddx in forum Performance
    Last Post: 10-20-2002, 06:21 PM
