I got a friend who has an 85 accord that doesn't work very much. I havent been able to find to much about the 2nd gen Accords, but I see you can swap a B series into a 3rd gen with the place racing mounts and axels.
Now for 85 one though, I already have a B18B left over from the swap on my integra, will the gen3 mounts work in the gen2?
Also since the car is carbed, could I do an EFI conversion if I used the entire harness from the integra and its ECU as well as run some lines to the fuel take and possibly use an Integra fuel pump? Basically replacing everything with the B series stuff?
Also what kind of transmission was used in the 2nd gen? Was the clutch hydrolic or cable. The shift linkage, cable of bars?
Also will the axles that place racing sells work on the gen2?
If I can make this fun for say under 4 grand it may look feasible.
One last question. Can the JDM B20A motor that you guys talk about use a B18B head? But then again at 160HP thats better than even a B20Z from 3 years ago.
