Results 1 to 5 of 5
Thread: 89 EXi 16V Vibrations over 60mph
    Jan 2020
    Accord CA5
    Germany
    Hello, ( first, please dont be mad about my bad English but im from Germany and the Honda Comunity here isnt that big, 3rd gen Accords even less)
    ich have a 1989 Accord Exi 16V ( 133HP ). The problem is that over 60mph the Car is shaking really hard. Not everytime but most of the time. At first it was feeling like the Driveshaft, but now there are new shafts on both sides. Its still the same. You can even reproduce the problem by lift the car up ( on 2 jacks, or i did it at my hydraulic lift) and accelerate. Even then its the same.
    I really hope that some of you might be able to help.
    Thanks alot.
    Greetings from G,
    Jan
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: 89 EXi 16V Vibrations over 60mph
    Put the rear wheels up front and see if it happens
    Jan 2020
    Accord CA5
    Germany
    Unfortunately I already did. And renew all balance weights on the tyres. So tyres are perfect matched.
    Suspension issue can't be because it's also when lifted and there is no pressure on the coils, suspension and so on.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    What about no wheels? It might go away due to less rotating mass, but if not it narrows it down.
    Fine in neutral?
    Wheel bearings ok?
    There really isn't anything BUT the suspension to cause vibrations like that at speed, so start with a careful and thorough suspension check. A wheel bearing coming apart will still act up, even if the suspension is unloaded. Pay special attention to ball joints. If they come apart, you'll be super sad, super fast. As you inspect, be watchful for anything out of the ordinary. If you've been ignoring those leaky shocks or torn up mounts, now's your excuse to fix them. Also check your tires. They could be separating, which causes weird vibrations. If they are in good shape and haven't been balanced in awhile, then do that too.
    When and how did this start?
  1. Vibrations
    By estooie in forum Classic Honda Community Chat
    Last Post: 12-13-2010, 10:32 PM
  2. all's good till 60mph then its all bad
    By kji420 in forum Carburetor Tech
    Last Post: 07-21-2006, 07:05 PM
  3. The steering Wheel vibrates when the car reaches 60MPH
    By Mario Calero in forum 3geez Accords
    Last Post: 03-11-2006, 11:11 PM
  4. vibrations need help
    By EricW in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-09-2005, 06:08 PM
  5. you 0-60mph time ( 0-100km )
    By ACCORD EX in forum Classic Honda Community Chat
    Last Post: 06-12-2003, 02:57 PM
