Results 1 to 5 of 5
Thread: Baro Sensor
    Nov 2017
    Baro Sensor
    I have a code 13 and my car jerks around 2k. Where can i find a Baro Sensor other than a junkyard? Are the Baro sensors after 3rd gen part of the ECU? thanks
    Nov 2017
    Re: Baro Sensor
    Went to the junkyard today here in San Antonio Tx and found two sensors 16 bucks. The first one I installed did the trick CEL is out.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Baro Sensor
    Can you post a picture of the sensor you are talking about? If its one of the ones I am thinking about you made the right call, glad it worked any way.
    Nov 2017
    Re: Baro Sensor
    that's the one
    Jun 2021
    Accord
    FL
    Re: Baro Sensor
    Quote Originally Posted by tad70 View Post
    Great to hear it was an easy fix for you! We will be working on this incoming Accord project with a few codes including 13. We'll just finish installing the front bump and amp research board on the truck this week before we can clear the garage and take her in. Gonna visit the local junkyard soon.
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. ecu flashes 13 times. BARO sensor?
    By Josh89accord in forum 3geez Accords
    Last Post: 03-02-2009, 09:32 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Location on BARO sensor
    By 3rd gen 89 se-i in forum EFI Tech
    Last Post: 01-21-2005, 11:44 AM
