Results 1 to 11 of 11
Thread: CV boot grease
    Jun 2010
    CV boot grease
    So I have a couple boots that have some tears, the joints are fine just the rubber is old and worn out so they squirting grease.
    Picked up some boot kits off rockauto cause they're way cheap and one of the kits you can tell is super old. Well really they're all old because they're all made in USA lol.
    They all come with a pack of grease but this one kit that looks way older than the others (by the box, you can tell it's been sitting on a shelf for a while), has a packet of grease that is green. Now, I've never seen green grease before so I am bewildered... the grease just old and I shouldn't use it? Or is there a such thing as green axle grease?
    Side note: The kits are old but the rubber boots are in surprisingly great shape, not dry rotted or anything.
    Thanks.
    Originally posted by ShiRen:
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    Re: CV boot grease
    Id use it as long as the rubber is good. Give it a good test, twist it with your hands to see if you can get any dry cracks to show in the boot when you stretch it. The green grease is probably synthetic grease so its the high quality stuff. I have not known of oil or grease to go bad in a sealed container.
    1988 Honda Accord LSDX-I
    Jun 2010
    Re: CV boot grease
    both outer ends are cracked and oozing, driver side got finished off when I pulled the axles the other day. The pass side inner boot is coming out from under the clamp so it flung grease everywhere, yay.
    Re: CV boot grease
    Replacing boots is a job I don't need to do a 2nd time. It was such a mess, I'll gladly buy the axles now. Kudos to you though.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: CV boot grease
    Seriously, Rock Auto axles are cheap. Only time I'd mess with boots is if I was making a custom axle or putting high angle boots on and even then I would do everything I can to get around it (mostly because I'd need to do it every time I need an axle)
    Jun 2010
    Re: CV boot grease
    eh, want to learn so why not. I expect a mess.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: CV boot grease
    It might be easier to disassemble the joint from the shaft than to spread the boot around the whole joint. If that involves removing all the balls from the outer Rzeppa joint I would retract that statement though.
    Jun 2010
    Re: CV boot grease
    Well the outer joint didn't want to come off the axle shaft so I switched sides and the inner join came off with one hammer strike so yay. Both ends needed to be replaced anyway. Just slid the outer boot down to the joint and all is well.
    wasn't all that messy actually since most of the grease had been flung out lmao
    Jun 2010
    Re: CV boot grease
    nah, the outer joint you dont have to take apart completely, it can be hammered off but it's easier to take the inner join apart since it's only held captive by the boot itself and all that needs to be removed by force is the three prong looking thing (no idea what the official name for it is lol)
    Jun 2010
    Re: CV boot grease
    well I ended up just buying the passenger side axle since I found a hole in the inner boot on the old one that I didn't see before and didn't order a replacement for... oof
    plus the store had a brand new one, not a reman so why not eh
    Re: CV boot grease
    Pretty sure I threw my pants away after that job. There was no getting that grease out of them.
  1. Choosing the right grease for your application
    Last Post: 02-01-2010, 10:20 AM
  2. Speedo cable grease
    By russiankid in forum 3geez Accords
    Last Post: 05-13-2008, 02:35 PM
  3. grease monkey check in
    By 86LXItooFAST4me in forum 3geez Accords
    Last Post: 06-11-2004, 06:05 AM
  4. best product to clean grease?
    By T-Funk in forum Interior & Exterior Care
    Last Post: 09-23-2002, 10:04 PM
  5. What type of Grease?
    By Chris86Lxi in forum Classic Honda Community Chat
    Last Post: 07-11-2002, 06:44 PM
