Results 1 to 6 of 6
Thread: dist cap seal?
    Jun 2010
    dist cap seal?
    so since I had the car apart I was addressing some other minor issues, one being the distributor advance being loose and wiggling around. Probably why I've been getting random spitting out the carb throats...
    Anyway, so the seal around the cap is basically destroyed and I peeled off what was left. Problem is now I cant find that particular seal or gasket anywhere. Is it not made anymore or what? Every cap I've bought doesn't come with one.
    All that shows up is the mounting o-ring and another internal seal.
    Originally posted by ShiRen:
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: dist cap seal?
    I've never seen one, the dizzies don't even have an embossed area for an oring except where the wires go in. I have never seen any issues with it sealing either, but I wouldn't recommend spraying it with water with the car on. I assume you have the TEC?
    Jun 2010
    Re: dist cap seal?
    TEC yea. There was the remains of a seal there. Tightening down the cap, there is a noticeable gap between the cap and body of the distributor like something should be there..
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: dist cap seal?
    That's strange... I put a paper gasket on my old TEC, but it didn't do anything functional, probably wasn't water tight and the cap seated flat anyway. At some point I am going to sound like a broken record, but I'd swap the TEC out for a hitachi anyway, they're a lot nicer made.
    Re: dist cap seal?
    The only oring they had was a very thin oring that ran in a groove in the cap. I haven't had one for years and haven't noticed the difference. The cap should draw up tight against the housing though. You should get that figured out.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: dist cap seal?
    I don't know of any aftermarket cap that still uses an oring. I know for a fact the one I put on my TEC, I think it was from autozone, did not have a groove for it, hence why I thought it was necessary to make a paper gasket. Neither of my Hitachi caps had one either. Oem might have had one.
  1. crankshaft seal aka front main seal
    By l0l in forum 3geez Accords
    Last Post: 04-14-2012, 06:50 AM
  2. Amp getting Power but not dist to Subs
    By w00tw00t111 in forum Interior & Exterior Care
    Last Post: 04-22-2005, 08:09 PM
  3. Best timing in the dist
    By HC_LXi in forum Performance
    Last Post: 12-08-2004, 04:53 AM
  4. DIS from the dist....
    By maka_RTH in forum Performance
    Last Post: 09-16-2004, 08:59 PM
  5. Want To Trade: Dist. For Engine
    By BootMachine in forum Trading Post
    Last Post: 01-12-2004, 02:12 PM
